diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Class D (https://www.diyaudio.com/forums/class-d/)
-   -   Bluetooth module /amp without volume control (https://www.diyaudio.com/forums/class-d/318311-bluetooth-module-amp-volume-control.html)
alice1234 2nd February 2018 08:44 PM
I'm playing around several Bluetooth modules equiped with Class D amplifiers where you have two volume controls: one on the source and one on the amp itself, mostly using push-buttons or a remote control. From what I understand, the blueooth chip contains a volume control.
I would like to make it differently: a single Bluetooth module (4.0 / APTX or higher preferred) and a separate amplifier where the volume is not adjusted within the bluetooth receiver, but by the amp itself.
Is there a bluetooth (4.0 / APTX or higher) module without integrated volume control to as to send the audio at the volume set on the source ?
Thanks.
bitSmasher 3rd February 2018 01:47 AM
Sure Audio comes to mind straight away:
Sure Electronics' webstore Bluetooth V4.0 Audio Receiver Board w APT-X - BRB3
Would be plenty of other options if you're willing and patient enough to trawl through ebay or aliexpress
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
