diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Class D (https://www.diyaudio.com/forums/class-d/)
-   -   Any class d blutooths powered by micro usb? (https://www.diyaudio.com/forums/class-d/316929-class-blutooths-powered-micro-usb.html)
Blueandy88 3rd January 2018 05:30 PM
Building a little speaker set up for travel and have a solar powered 15000 mah battery pack that accepts usb to run power to . Any class d amps have a provision or are they all pretty much 2.1-2.5mm power jacks?
Nenola 5th January 2018 03:57 PM
I recently built a bluetooth speaker with this Sanwu board: Stereo Bluetooth Amplifier Board Lithium Battery Powered AMP for Speaker | eBay
Tested it with usb power and it works. But I have to warn you, i makes a loud and annoying beep when turned on. Currently I'm powering it with one single 18650 lithium battery. Haven't tested the charging feature yet.
I think your speaker will run for days with that battery! :D Might wanna think about smaller pack if you wan't to save space and weight.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
