diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Parts (https://www.diyaudio.com/forums/parts/)
-   -   what is this called and can you get them (https://www.diyaudio.com/forums/parts/314630-called.html)
garybdmd 10th November 2017 01:42 AM
2 Attachment(s)
I have pcb switch horizontal mount that has a 3.3mm square end that a cap goes on. As you see in the image, I drilled holes for the cap to slide through but you have to be pretty precise to get it to work well so the cap doesn't get caught up on the faceplace hole. In other words, the holes have to be drilled pretty preciselty.
I was wondering, I would like to drill a hole that the stem of the pushbutton switch goes through. But instead of a plastic cap, I have seen these rubber squishy caps. Basically you press in on a squishy rubber cap and it compresses. This seems like it would be much more forgiving when drilling the hole.
1) what are these rubber squishy switch caps called?
2) do they still make them and where can I find them?
Einric 10th November 2017 01:46 AM
I would try and search for, Push Button Switch Boot
Mouser.com seems to have quite a few different switch boots to pick through.
garybdmd 10th November 2017 06:12 PM
Thank you
Thanks for the terminology. I will post what i find later in case anyone is interested
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
