diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Everything Else (https://www.diyaudio.com/forums/everything-else/)
-   -   How to remove variable cap from a radio (https://www.diyaudio.com/forums/everything-else/313209-remove-variable-cap-radio.html)
bancika 8th October 2017 01:30 PM
I'm trying to restore an ancient transistor radio Telefunken Partner 1. Anyone knows how to release the variable cap from the tuning dial? It seems to have one screw that keeps it in place. I suspect that the brass Telefunken logo on the dial is the screw, but I'd like to confirm before trying to open it with a tool, it's a bit stuck, so fingers alone don't help.
https://farm9.static.flickr.com/8143...db190ec5_b.jpg
https://www.abetterpage.com/wt/photo...s1351x1022.jpg
DF96 8th October 2017 02:04 PM
The centre part of the dial may just be a push fit and can be levered out. There will probably be a screw underneath. However, sometimes the whole dial is just a push fit onto the variable capacitor shaft.
DUG 8th October 2017 02:30 PM
Possible similar issue here?:
Telefunken Partner 2 - UK Vintage Radio Repair and Restoration Discussion Forum
bancika 8th October 2017 03:00 PM
Yes, same issue. Thanks both of you!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
