diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   AKSA (https://www.diyaudio.com/forums/aksa/)
-   -   Increasing the bias current on my NAKSA80s & Sorayas ... seems to be a good thing!! (https://www.diyaudio.com/forums/aksa/310323-increasing-bias-current-naksa80s-sorayas.html)
andyr 24th July 2017 06:49 AM
In my system (actively tri-amped Maggies driven by 2x NAKSA 80s (for mids & ribbons) and a Soraya on the bass panels), I suffer from a lack of soundstage depth. Unfortunately, this is due to the (lack of) distance between the Maggies and the front wall - which is caused by the room dimensions. I may be able to improve soundstage depth by treating the front wall with diffusion products but, in the meantime, with Hugh's advice, I decided to increase the biasing of the amps.
Hugh told me that increasing bias delivers more soundstage depth and suggested I could double the bias currents without causing any problem for the output devices - this means:
* 70mv across the 0.33 ohm res (R22) on the NAKSA 80s (instead of 35mV), and
* 120mV across the emitters of the outermost output transistors on the Soraya modules (instead of 60mV).
As increased bias means increased heat into the heatsinks, I decided to go slightly conservative - so a bit less than twice the stock bias:
* 60mv across the 0.33 ohm res on the NAKSA 80s, and
* 110mV for the Soraya modules.
I'm hoping my heatsinks will be able to cope with this in summer - as the result is delightful! :) Yes, a bit more depth ... but also more 'body' to the sound! :D
So this is something that AKSA owners might like to try out.
Andy
saf 24th July 2017 09:01 AM
Wow...this is a very easy trick ! Hugh, does this apply to the Mayas too ?
AKSA 24th July 2017 09:38 AM
Thanks Andy!
Felipe, I have taken the Maya to 150mA (54mV across the two 0.18R source resistors, TP1 to TP2) and it does grow a little scale. But I'm reluctant to take it more because with 65V rails, the heat dissipation is starting to move up, particularly in a hot climate.
You could take it up to 200mA for a brief period if you wish, that is, 72mV. But it's dissipating 26W at each of the two outputs into a 0.27C/watt heatsink, and this would mean 15C above ambient at idle, and considerably more heat if it's working hard.
You Maya is going well, Felipe? Are you as happy as you were a month back? I do hope so...... today I visited a Melbourne customer, Russell, who has a 125W Maya on recent Harbeth large, stand speakers - beautiful speakers, absolutely wonderful. We compared the Maya with a DIY 2A3 SET amp with 3.5W per channel, and we come to the same conclusion that the Maya was almost as musical but a little more clear than the SET, with a similar sound stage, very good depth. I was pretty happy about that.....
Hugh
Sjef 9th October 2017 07:37 PM
Would this also work for the older aksa70 as I have two in my bedroom system that lack a little live and sparkle in general.
AKSA 9th October 2017 09:54 PM
No, do not do this with the NAKSA 70. Bias control is not to precise as the 80 and the Maya, and taking it out to high quiescent is dangerous. Best left around 70mA, no more.
Hugh
Sjef 10th October 2017 06:59 AM
Ah, great info, thanks. I'll leave it as it is.
AKSA 10th October 2017 08:31 AM
Sjef,
I sold the NAKSA 70 only about a year, and had a couple of failures as a result of enthusiastic fiddling with the bias. I thought about it over quite a bit of time, did some tests, and found that over about 110mA I could lose temperature control of the output stage in some situations, particularly hot weather and strong bass. It prompted me to release a major redesign, the NAKSA 80, and for nearly three years have had no failures of that model. I am extremely cautious about temperature compensation on my amps now, and take pains to ensure that increasing temperatures in arduous conditions the quiescent REDUCES, to prevent thermal runaway. I have honed this approach over a couple of years and my new amps have sophisticated temperature control, using direct sensors on the output device, to measure heat very quickly and react immediately. I have found this issue critical in powerful amps using very large mosfets, like my Maya, which uses very large 480W devices featuring huge transconductance, that is, small increases in gate voltage result in huge increases in drain source. Thermal management in large amplifiers is similar to controlling a nuclear reactor, get it wrong, and there is a lot of smoke and fire!
If you are worried about the top end of the amp, which is actually very good on the N70, examine the other areas of the system, particularly the tweeters on your speaker, or perhaps the source.
Hugh
Sjef 10th October 2017 05:43 PM
That might explain why one of the amps runs warmer then the other. I'm using them in an active threeway system for mids and highs. In fact I like their treble the best as it keeps good control over a pair of old ess sir motion transformers with can get a little harsh on lesser amps. I was more talking about midrange, while pretty good just not as lush as a real classe A. Nevertheless highly enjoyable.
What is your view for the long term regarding temperature management. I tend to keep my equipment for periods of more then 10 sometimes even 25 years. Should I be worried about it?
AKSA 12th October 2017 07:36 AM
Hi Sjef,
Long term should be fine if you ensure all quiescents are set at 70mA.
If one is hot and the other cool, they are unequal, and should be corrected.
OTOH, I have later, better models now; NAKSA 80 has better top end, and SAKSA 80 has better midrange, but of course more designs cost you (and me!) more money.......
Despite my constant attempts, I cannot apologise for my latest amps sounding better than the older models! It's just life...... like buying a new car, and peeling an onion.
Ciao,
Hugh
Sjef 12th October 2017 09:15 AM
Hi Hugh,
It's not that one amp run hot. In fact it only runs warm, around 30 degrees or fo while the other one remains at almost room temperature. Both amps are virtually doing nothing. They drive a 93db / 16 ohm midrange driver from 150hz and a 95db / 8 ohm tweeter from 3500hz on up.
No need to apologize for anything, offcoarse there is always something better. I don't have any problems with that.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
