diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Swap Meet (https://www.diyaudio.com/forums/swap-meet/)
-   -   Mercury(?) relay boards for sale (https://www.diyaudio.com/forums/swap-meet/30168-mercury-relay-boards-sale.html)
JohnG 13th March 2004 06:56 PM
2 Attachment(s)
I have for sale 3 HP data aquisition boards for sale. Each board has a total of 16 SPDT relays that I believe are mercury relays (although I'm not taking them apart to find out for sure!). The boards are HP 03497-66514 boards, and two of them use Fujitsu FMR-878D10/1CS relays, and one uses NEC MSP-510N relays.
I have search the web and haven't found anything, so here's why I think they are mercury relays: First, they are marked with an arrow pointing up, which is typical of mercury relays (not counting Hg-wetted reed relays), and second, it sounds like there is mercury in them when you shake them.
It looks like the drive voltage is 5V, and they may have internal catch diodes since I don't see any external ones. I have spot-checked a few relays to verify SPDT operation and 5V coils, and have checked that all the relays at least click with 5V applied to the coil.
Beyond that, I do not plan on doing additional testing. However, the boards look clean and came out of a well treated DAQ system, so I suspect they are in good shape. I'm asking $25.00USD or each board or $60USD for all three.
These would make fine relays for that low-noise preamp, which is why I hung onto them. Alas, they have sat on a shelf for three years, so I hope they may go onto a better life.
US only please, cashiers check, money order, or paypal.
Best regards,
John
JohnG 14th March 2004 07:38 PM
Ok, $50USD for all three (48 relays in total). Save them from the trash heap (don't worry, they would go into the mercury waste drum at work).
John
JohnG 20th March 2004 02:22 AM
Last chance before the trash. $25 plus shipping for all 3 boards.
John
li_gangyi 20th March 2004 02:31 AM
I would like to have them if I weren't in Singapore...shipping is gonna be ex...
tcpip 15th April 2004 05:22 PM
Quote:
Do you still have the boards? I just found this thread by Googling.... I'd be happy to pick up all three if they're still available.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
