diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Pass Labs (https://www.diyaudio.com/forums/pass-labs/)
-   -   Pearl and Benz Micro Cartridges (https://www.diyaudio.com/forums/pass-labs/28748-pearl-benz-micro-cartridges.html)
Stabist 23rd February 2004 01:13 AM
Hi!
Some of my friends and I own couple BenzMicro Cartridges - Aces or Gliders ...
We were thinking of building up few Pearls for our systems - but - is Pearl suitable for MC cartridges? Some says it is and some says it must be "upgraded" if you want to use it as an MC preamp ...
Thanks for tips!
Nelson Pass 23rd February 2004 03:19 AM
What upgrade did they have in mind?
Stabist 23rd February 2004 10:03 AM
Here's a copy/paste - original written by mr. Panelhead and published on analogue section of this forums - of one modification of the Pearl:
"If you like the sound of the Pearl, why not add a gain stage to the input. Several others have done it with good results. The input stage of the Pearl is a great circuit to start with.
Mine is a pair of matched 2SK170BL, each sitting on a 22 ohm resistor. The pair is cascoded with a ZTX450.
Power comes off the Q5 second regulator of the Pearl. Through a 10 mH choke, 1000 ufd cap, then 700 ohm resitor to the ZTX450. The output is cap coupled with a 1 ufd stacked film and foil cap into the 47K input of the Pearl."
Panelhead 23rd February 2004 11:02 AM
Re: Pearl and Benz Micro Cartridges
Quote:
Originally posted by Stabist
Hi!
Thanks for tips!
The use of the Pearl with medium output MC cartridges will be dependent on overall system gain.
In my system, the resulting gain was too low trying a Grado Statement Sonata and a Denon 103R. Audio Note UK Stepups were tried, but the bass was very flabby.
Another problem was loading, thr Grado is a very low output MI, it likes to see 47K. The Denon likes around 100 ohms.
I built the simple circuit and it is great. The transformer was great with my last two tube phono's.
The noise level is much lower coming grom the Pearl with MC pre compared to the tube and step up iron.
George
Nelson Pass 23rd February 2004 06:07 PM
Wayne reports that the Pearl doesn't really have adequate
gain for the Benz Micro. Additional gain does improve the
situation.
Duck-Twacy 23rd February 2004 07:44 PM
Benz Ace comes in 3 flavours eh, colors
Red: low 0.4 mV
clear: medium 0.8 mV
blue: high 2.5 mV
I got the clear version
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Stabist 25th February 2004 10:27 PM
situation.
Thanks for the info!
Stabist 25th February 2004 10:31 PM
Quote:
Originally posted by Duck-Twacy
[B]Benz Ace comes in 3 flavours eh, colors
Red: low 0.4 mV
blue: high 2.5 mV
Hmm - I knof that also Glider in "Medium version" should be around 0,8mV - but on the "datasheet" that came with mine it says it 1,0mV ... Well, even better for me ;) :D
Boban 26th February 2004 02:12 AM
or add Lundahl LL9206 transformer. I did it last year and am more than happy with my Pearl.
Boban
Posthorn 26th February 2004 03:25 AM
Sowter is also a well known source for step up and tube transformers.
Prof Leach shows some ways to solve the problem.
I would prefer Stabist sugestion or, if you like to go the next step, add the complete first stage with regulator.
If this is not a choice for you ask Wayne what's to do.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
