Original Pass B1 PCB partially populated
Disabled Account
Joined 2012
Because of a change in gear I have for sale a partially populated, fully Original(From Pass) B1 PCB.
It is populated with:
2 x 1uF Obbligato gold caps
2 x Nichicon KE 4700uF caps
Some resistors, a LED and more
I can provide 2 matched 2SK170 sets in the right range if you wish(Original ones)
I also have 2 obbligato 10uF caps for sale to go with it, or 2 x 10uF Obbligato PIO caps. Your choice, or no choice at all :D
Furthermore I have 4 x naked Z-Foil precision resistors 1M to put on the boards. If you ask nicely, I will even solder them on for you :)
All of the above is used(exept for the Fets) but in prestine condition. Not even played in yet!
So, if you want a near complete set, PM me with your offer.
Cheers.
