diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Chip Amps (https://www.diyaudio.com/forums/chip-amps/)
-   -   TDA7294 + LM3886 Amp 5.1 (https://www.diyaudio.com/forums/chip-amps/275630-tda7294-lm3886-amp-5-1-a.html)
kulamario 11th June 2015 10:47 AM
Welcome
I wanted to make myself amp 5.1 based on TDA7294 in bridge on the subwoofer and 5xLM3886 on other channels but the creation of the PCB is too hard for me
or maybe someone from colleagues has such a project and can share the schematic and PCB?
of course buying from Ebay.com also does not come into play too expensive
TDA7294 + LM3886 5.1-Channel Power Amplifier Board AC double 20V-24V | eBay
AndrewT 14th June 2015 11:33 AM
Use a two channel amplifier for the two rear channels.
Use a two channel amp for the two front channels.
Use a two channel amplifier for the centre channel and the bass only channel. This last can use the same power if the centre channel and the bass speaker have the same impedance and the same sensitivity.
If the bass speaker has a low sensitivity, then it will need more voltage to sound as loud as the centre channel.
Three two channel amplifiers are easier to build than a 6channel amplifier and get right.
kulamario 14th June 2015 06:50 PM
Yes but i want have all on one PCB 5xLM3886 and 2xTDA7294
AndrewT 15th June 2015 09:20 AM
Where are the speakers?
All stacked together in one corner of the listening room?
No, they are spread around the listener.
Locate the amplifiers beside the speaker that each are driving, using short speaker cables and longer interconnects.
kulamario 15th June 2015 10:52 AM
Welcome
This is what I wanted to have the whole AMP one tip of the printed circuit board pcb
just to install it on the original heat sink from TEAC AG-D8800
Arty 16th June 2015 12:20 AM
long interconnects??
i would prefer long spekaer cables if i had to choose.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
