diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Swap Meet (https://www.diyaudio.com/forums/swap-meet/)
-   -   PCBs for a high quality Headphone Amplifier (Audioxpress 6/2013) (https://www.diyaudio.com/forums/swap-meet/263532-pcbs-quality-headphone-amplifier-audioxpress-6-2013-a.html)
gdan 18th October 2014 09:33 PM
1 Attachment(s)
I have available a very small quantity of PCBs for building the headphone amplifier as described in my article in Audioxpress June 2013.
You can find the article online if you have missed it :
Build A High-Quality, High-Power Headphone Amplifier | audioXpress
If you are interested, send me an email at: gntanavaras@gmail.com
gdan 27th October 2014 04:53 PM
Please note that 2 PCBs are required for the construction of a stereo amplifier.
gwrskien 31st October 2014 07:49 PM
Hello,
what is the price?
gdan 31st October 2014 09:11 PM
The price for each PCB is 30 euros.
Two PCBs are needed for a stereo amplifier.
gdan 16th November 2014 05:29 PM
The price is reduced to 25 Euros for each PCB.
gdan 6th December 2014 03:08 PM
A few PCbs are still available.
adydula 13th January 2015 12:45 AM
If I want only to build one for headphones, unbalanced would I still need 2 boards?
Alex
gdan 13th January 2015 07:03 AM
Each PCB contains the components for the raw Power supply, the regulated Power supply, the protection circuit and one headphone amplifier.
So if you want to build a two channel headphone amplifier you will need 2 PCBs.
gwrskien 4th June 2015 03:36 PM
Hello,
Are these still awailable?
I have problem finding the relay in the article bom, could this be used?
G6A-274P-ST40-US-DC9
G6A-274P-ST40-US-DC9 Omron Electronics | Mouser
Thank`s
Gisle
gdan 4th June 2015 08:40 PM
I have some DS2E-M-DC9V relays available. If you are interested send me a email at:
Of course you can use any other relay if the dimensions and the layout are the same with the above relay. But you should recalculate the resistors R29, R35 and R36 so that the voltage on the relay is close to its nominal value. Otherwise you could overdrive the relay and it will get really very hot. You should check also that the temperature on the body of the resistors is normal.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
