diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Parts (https://www.diyaudio.com/forums/parts/)
-   -   Quality 2 input rotary selector switch (https://www.diyaudio.com/forums/parts/263524-quality-2-input-rotary-selector-switch.html)
semmyroundel 18th October 2014 06:41 PM
Hi, Im in the UK and am building a 41hz amp 15ps Xp kit (for my sins), yes I know, why did I buy from there?
Well it came in quick time, which is more than I can say for any documentation, or email assistance, especially after some Turkish guy hacked the site (it would appear from the home page)
Anyway, I've got on order a 625va, 0-55v vigortronic trafo, and am looking at a 50k Alps pot, is that right, or should it be 100k?
Also as the title suggests, despite searching this forum I can't find a source for a 2-position quality input rotary selector switch, ideally with a 6mm shaft so I can match the knobs on the front (although that's secondary to sound quality).
Can anyone help? Here in UK remember, and also do Alps do one?
Thanks people
semmyroundel 19th October 2014 02:35 AM
Gee thanks for your input guys!
50 views and no replies.
I did find some on hificollective, I take it I need 2 pole and however many inputs I need (2 in the case of cd and tuner) although you can only buy 6 input and upwards, heaven knows why someone would want a 24 input selector switch!
Can anyone recommend which one to buy without going ape on the money?
Snake oil not appreciated.
davidsrsb 19th October 2014 02:20 PM
Because we normally use a DPDT slide or toggle switch rather than a rotary for 2 way?
Rotaries can have their rotation reduced by moving the stop, but usually are avoided as they cost far more
SRMcGee 20th October 2014 08:43 PM
semmyroundel:
You should check out the switches from Greyhill.
Regards,
Scott
semmyroundel 22nd October 2014 09:11 AM
thanks guys, grayhill don't seem to do 4p3t in Uk so postage costs are astronomic.
I'm going to start another thread about whether to switch grounds to avoid loops, which may enable me to get 2p3t switch (much easier here) and M before B or B before M
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
