diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Digital Source (https://www.diyaudio.com/forums/digital-source/)
-   -   Audio Streamer for 24/192 or 24/96 options (https://www.diyaudio.com/forums/digital-source/257423-audio-streamer-24-192-24-96-options.html)
barackuda 7th June 2014 06:46 PM
Hi all.
I am in need of an audio/video streamer that can output Hi-Res audio via Optical or Coaxial.
Basically what I want to do is put it inside a case of a Teac PD-H500 CD player. I bought the amp and two cd players, one of them faulty. Thats not a problem as it was only 20 pounds. I also bought the Teac UD-H01 DAC and looking to play some Hi-Res files but not throu a PC.
What I would need is a streamer about 200x200 size and no more then 100mm high to fit in that case, with the remote sensor on the lower side so it works throu the original display window.
Also would be good if it had some storage area or capable of connecting external HDD/pen drive/SD card/whatnot....
IMPORTANT: if its a media streamer capable of outputing these formats, the optical and HDMI out have to work simultaneously and also not require me to connect a tv (could mount a 5 inch screen on the front of the case)
thanks for suggestions
Danny
barackuda 7th June 2014 09:43 PM
Nobody with experience with media/audio streamers? Do they work with Hi-Res out over Toslink?
kevinkr 7th June 2014 10:04 PM
Look into the Raspberry Pi and any number of projects here for something suitable. Toslink sucks.. :D
barackuda 7th June 2014 10:21 PM
I am not sure if raspberry will be able to handle high bitrate hd movies. it might suck, but majority of the players have only optical, hdmi and sometimes component and video out. thats it what I could find out.
I need video out for the front screen, hdmi for tv connection and optical (coaxial) for hi-res music
danny
kevinkr 7th June 2014 10:31 PM
It was intended to support 1080P and has a DVI format HDMI output. I would check it some of the threads here. There are a number of dac boards designed to interface directly with its I2S output and I believe that someone is working on a spdif output as well. (Actually there are piles of hardware intended to interface with the Pi, just need to look for it) It has GPIO as well for controlling stuff like simple displays.
barackuda 8th June 2014 11:20 AM
I read a lot that its good but has one major drawback....its slow.thars what the others report.
Does anybody know if media players output through HDMI and optical/coaxial/composite video at the same time? or does the output turn its self off once some other is connected?
this way I could run the front screen from Comp video and output from S/PDIF to DAC and when desired the HDMI to a tv....
danny
Studio Au 8th June 2014 11:38 AM
Mac Mini? Has become my media server of choice.
The Appel Airport Express are great but capped at 48Hz. I read apple are prepping a hi-res itunes and hi-res lightening cabled headphones, perhaps the next apple tv will up the bitrate and be a good contender.
keres 8th June 2014 11:50 AM
Nuc intel or mac mini
Inviato dal mio SM-N9005 utilizzando Tapatalk
barackuda 8th June 2014 12:44 PM
hey guys thanks for suggestions...but no Mac for me or any if that iCrap devices.Had them for 3 years as company gear...didnt like them at all.especislly iTunes.
I'll might give a try to WD live tv hd or some of the Asus media players. Hope the HDMI and comp video out work at the same time....
barackuda 8th June 2014 02:43 PM
WD is out... read on another forum that it downsamples to 48kHz....192kHz crashes on it...
Great.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
