diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Parts (https://www.diyaudio.com/forums/parts/)
-   -   Switched mode power supplies (https://www.diyaudio.com/forums/parts/25222-switched-mode-power-supplies.html)
Magura 2nd January 2004 10:18 PM
Whats the current status on SMPS ?
During the last couple of weeks ive read a few comments like "no big deal" and "ive made several that works fine".
I need a lot of power, like 40A 12 to 30V.
Anybody made something like that that actually works?
AND with a reasonable reliability and expected life to it???
Circlotron you mentioned that SMPS is a nogo no matter what, since i know theyre part of your profession, id like to have a short explanation why it is so.
Magura
Sch3mat1c 3rd January 2004 01:31 AM
All I've heard is that they are noisy as all hell but nobody's yet given me a reason why this noise can't be filtered, so go for it. I've tried a little work with flyback supplies and have had up to 10W output, I need a larger "spring"...
Tim
Magura 3rd January 2004 01:34 AM
well...monster size inductors are is the smallest problem. I havnt got much clue about the rest, and at 40A this is dangerous i guess :D
Magura
Tony Salsich 3rd January 2004 01:46 AM
I did an off-line, 30V/1kw supply for a customer. It was a 200khz, full bridge forward converter. Full bridge is a bit complicated, but the transformer was so small. I used a small PQ transformer with a center-tapped foil secondary. The primary was wound with triple insulated wire - great for meeting safety requirements. Rubadue, Furukawa and others make this kind of wire.
:eek:
Magura 3rd January 2004 01:51 AM
Sounds interesting, got schematics for it?
How big is such a thing?....expensive??....reliable??
Magura
Tony Salsich 3rd January 2004 01:58 AM
I can get it to you in a few days. Yes, a bit expensive. It was part of a much bigger system: 1kW PFC front end, four independent full bridge outputs (for driving thermo-electric coolers). Basically a big pain in the ***, but also a great learning exerience. Each pice of the system was pretty straight forward, but making them all play together on one board was tough. It did meet class B conducted emissions though.:rolleyes:
Magura 3rd January 2004 02:00 AM
what is the expected life of such a monster?
Magura
Tony Salsich 3rd January 2004 02:01 AM
I don't know what should 'wear out'. Should last years.
jackinnj 3rd January 2004 02:11 AM
Quote:
Tim
as you filter a square wave, eventually you get a pretty good sine wave but then you reduce efficiency -- this is how I use a PIC as a low distortion oscillator --
take a look at Application Note 70 on Linear Tech's website -- they have the noise down to where it can be used in hydrophones, medical applications, etc. You can order the parts from Linear directly, they have a low noise gate driver using the same slew-control technology.
Magura 3rd January 2004 02:12 AM
How about getting +30-0- -30V, is that possible in a reasonable way?
How about an option to regulate the output voltage, lets say from 12V to 30V ?
Magura
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
