diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Subwoofers (https://www.diyaudio.com/forums/subwoofers/)
-   -   Easy horn (Eazy Horn) still work? Alternatives? (https://www.diyaudio.com/forums/subwoofers/252087-easy-horn-eazy-horn-alternatives.html)
Soldermizer 1st March 2014 02:24 PM
I just found Easy Horn (Eazy Horn) and tried it a few times but can't seem to get good results out of it. It look(ed) to be a good idea, but not updated for a few years. Does this tool work? Tutorials? Anything better out there? After my humbling Ijit Mark I failed build ("planning-free"), I am learning the wisdom to simulate first :)
GM 1st March 2014 02:50 PM
don't see why not.
IIRC it's designed to only provide a starting point to 'slide' your way to what you want/think/believe is an acceptable alignment in HR's Loudspeaker Wizard, so if it happens to provide a good one initially I imagine it's strictly a coincidence.
I see Soho still lurks, so maybe he will chime in.
GM
Soldermizer 4th March 2014 05:01 PM
After some more fiddling I figured out that horns will simulate better if I specify less than a 30x compression ratio :)
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
