diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Full Range (https://www.diyaudio.com/forums/full-range/)
-   -   Shed a little light pls:) (https://www.diyaudio.com/forums/full-range/242008-shed-little-light-pls.html)
msj965 5th September 2013 06:09 PM
What is the best way to set my amps speaker output impedance. I have a 6 ohms tower speakers but I don't know if 8 or 4 ohms will be the setting. I dont wanna fry my amps. thanks
ann
richie00boy 5th September 2013 06:21 PM
Setting the amp to 4 ohms would be the safest, if that is your main concern. Assuming it's not a valve amp.
chris661 6th September 2013 10:17 AM
I'd say set it to 4ohm, sounds like it is a valve amp - we probably wouldn't be having this discussion if it were solid-state.
6ohm nominal will likely drop to 4ohm in places, so I'd consider the 4ohm tap more appropriate.
mondogenerator 6th September 2013 03:22 PM
Id set to 4 ohm
The onset of THD is more gradual (so they say) and its safer for your tubes
tuxedocivic 6th September 2013 05:11 PM
I once used a Yamaha receiver that had a 4ohm setting. That was about 7 years ago. I guess it couldn't handle 4ohms well or something. Anyways, it was terrible on that setting. Really cut the power output.
But I don't really know amps at all. Tube amps confuse me even more.
balerit 6th September 2013 07:23 PM
Try the 8 ohm first as 4 ohms will double the load on the power supply and transformer.
richie00boy 6th September 2013 07:32 PM
Quote:
Originally Posted by balerit (https://www.diyaudio.com/forums/full-range/242008-shed-little-light-pls-post3622444.html#post3622444)
It's his amp not speaker that can be set.
balerit 7th September 2013 05:31 AM
Shot:up:.
AllenB 7th September 2013 10:18 AM
Valve amps tend to be sensitive to over-voltage (from a lighter load) the way a solid state amp may not like over-current (from a heavy load), so while a higher apparent load impedance may be a sonic choice I'd stop short of declaring it a 'safer' option with a valve amp.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
