diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Swap Meet (https://www.diyaudio.com/forums/swap-meet/)
-   -   moving give away . . . (https://www.diyaudio.com/forums/swap-meet/238711-moving.html)
ByronInPortland 4th July 2013 05:56 PM
4 Attachment(s)
Moving give-away! To make my life easier, I’m not going to combine all the drivers and passive radiators and miscellaneous stuff. So no cherry-picking! Taker pays shipping via USPS from Lawrence, KS. Box is 14 lbs.
4 Tang Band W3-881SI Tang Band W3-881SI 3" Speaker 299-113 Used for testing only, excellent condition
2 SB Acoustics TWD25NH-05-08 SB Acoustics TWD25NH-05-08 The cone of one is slightly dimpled.
2 Some crappy paper cone tweeter
2 Peerless 830880 passive radiators. The Madisound Speaker Store These came with weights attached. I was able to remove one without damaging the cone. The other still has the weight attached.
1 Vifa P17WJ-00-04 http://www.sea.vg/vifa/P17WJ-00-04_data.pdf Well used. This is, without doubt, the best driver of the bunch. Unfortunately, I only have 1, and they aren’t made anymore. This could be great for a center channel.
1 2.75” midrange from a Pinnacle center channel.
2 Peerless 830855 Peerless 830855 4" SDS Midwoofer 299-219 barely used. This is an amazing little driver as long as you don’t need high volume. Here is what I built with them. http://www.diyaudio.com/forums/subwo...subwoofer.html The cabinet has been thrown out.
Miscellaneous stuff: terminal cups, small flared ports, soldering iron, single Fostex L-pad, used plastic project box.
The broken soldering iron and torroid, I’ll ship separately to any takers. Taker pays shipping.
1 Broken Stahl tools soldering station and the parts (a resistor and rail triac) which I think might fix it. Stahl Tools TCSS Temp Controlled Soldering Station ESD Safe 374-200
1 400VA torroid with an internal short from Antek’s fire sale. I unwound it to try to fix it, but was unsuccessful. It could be good for lots of magnet wire
I’m also selling a pair of Audio Concepts DV-12 with cast frames on e-bay Audio Concepts DV 12 Dual Voice Coil 12" Woofers Two | eBay
1st photo, upper left to lower right: 1 Pinnacle driver, 4 Tang Band drivers, 2 terminal cups, 1 SB acoustics tweeters, 2 crappy paper cone tweeters, 2 passive radiators, 1 Vifa woofer.
2nd photo: Vifa woofer and Pinnacle driver
3rd photo: some of the miscellaneous stuff
4th photo: everything boxed up. Box is 14 lbs.
Capt Grogg 4th July 2013 06:46 PM
pm sent
ByronInPortland 4th July 2013 09:32 PM
The box-O-drivers is gone. The broken torroidal and broken soldering station are still available.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
