diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Full Range (https://www.diyaudio.com/forums/full-range/)
-   -   Pensils for Alpair 10.3 & Alpair 10p (https://www.diyaudio.com/forums/full-range/238125-pensils-alpair-10-3-alpair-10p.html)
planet10 23rd June 2013 07:12 PM
http://frugal-phile.com/boxlib/pensi...lan-300114.pdf
http://frugal-phile.com/boxlib/pensi...lan-140613.pdf
dave
zman01 23rd June 2013 08:00 PM
Interesting - a much taller Pensil 10.3... a lot of folks who wanted a higher driver position (closer to ear height) - now they get it.
Scottmoose 23rd June 2013 08:24 PM
Not influenced by that. The driver height is a function of cabinet length. And the cabinet length is a function of driver requirements and the target alignment. But yes, it does mean that people do have a greater driver height as a side-benefit, which is nice.
zman01 23rd June 2013 08:46 PM
Right Scott - I was alluding to the side benefit; I took it as a given that the box satisfied your performance oriented goals first. :)
Scottmoose 23rd June 2013 09:06 PM
There are those who might disagree. :D
Kastanza 24th June 2013 12:12 AM
Thanks mucho for those new Pensil plans.
Was wondering if a bookshelf design was on the table for the 10.3's?
planet10 24th June 2013 12:23 AM
Quote:
Originally Posted by Kastanza (https://www.diyaudio.com/forums/full-range/238125-pensils-alpair-10-3-alpair-10p-post3536885.html#post3536885)
I'm doing a full range of miniOnken.
dave
Octavia 24th June 2013 02:07 PM
Seems well suited for a 15 Liter bass reflex as well
Octavia 24th June 2013 02:16 PM
Scottmoose does your pensil for the 10p have the built in bsc as with the other pensils? If so that sure makes that little paper dimple driver all the more beguiling.
chrisb 24th June 2013 05:31 PM
Quote:
Originally Posted by Octavia (https://www.diyaudio.com/forums/full-range/238125-pensils-alpair-10-3-alpair-10p-post3537615.html#post3537615)
well, IINM, the BSC is actually engineered into Mark's drivers - which might simplify an enclosure designer's job? :D
or not? ;)
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
