diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Equipment & Tools (https://www.diyaudio.com/forums/equipment-and-tools/)
-   -   What soldering iron (https://www.diyaudio.com/forums/equipment-and-tools/221260-soldering-iron.html)
agold 10th October 2012 12:15 AM
What soldering iron
Hi there, I'm new to the hobby and just staring to build my tool set. Any recommendations on a soldering iron?
N Brock 10th October 2012 12:25 AM
Depends on your level of commitment. By which I really mean how much you are willing to spend :D
Something like this will get you a long way without being major $$. I've used it a few times and it's a good value.
Stahl Tools TCSS Temp Controlled Soldering Station ESD Safe 374-200
This is the station that I normally use. It hasn't failed me yet. You wouldn't need anything better unless you go pro or decide to solder every day.
Weller WES51 Soldering Station 372-145
Best,
Nelson
DUG 10th October 2012 12:26 AM
Depends on how much you have to spend and where you live.
Suggested (and recommended):
temperature controlled (your control)
60W-120W
A few different types of tips
spicolli 10th October 2012 12:34 AM
i use this on at home and work
Soldering Station - Digital Display - 48W [608-352NA] - $93.49 : Pro'sKit
i use this one you can find it alot cheaper than listed price think mine was around $70-80 with extra tips from Appleton Electronics Supply one of my local vendors
kct 11th October 2012 01:59 AM
I am using the fine Metcal and suggest it altho this unit is anything but cheap.
Features 'smart heat' and exchangeable tips.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
nigelwright7557 11th October 2012 02:14 AM
I solder quite a bit but just use a cheap soldering iron.
I did buy a couple of soldering stations but they died pretty quickly so I went back to just a simple cheap soldering iron and that has done well for about 3 years now just needing a couple of new bits.
agold 11th October 2012 02:48 AM
Thanks to all for the suggestions. I bought a cheep iron from RadioShack awhile back but It is very bad. The tip won't get hot enough to melt the solder and the handle gets way to hot. I don't want to make the same mistake twice so I'm willing to invest a bit on my next iron. Money is all ways a concern so I'm looking for a the best value out there
BeatleFred 11th October 2012 05:46 AM
I just bought this one on Ebay:
Hakko FX888-23BY Soldering Station - High-performance soldering tool | eBay
stratus46 11th October 2012 05:59 AM
Quote:
Originally Posted by kct (https://www.diyaudio.com/forums/equipment-and-tools/221260-soldering-iron-post3197129.html#post3197129)
I have one at work (my own), another at home and a spare power supply and wand though in 10+ years I've never had a failure. That's how much I don't want to be without it. We've bought 3 at work (besides mine) off eBay for $175, $190 and $250. Also my previous employer has 6 units - all from eBay. I've been soldering 50 years and nothing else comes close. Just my $0.02
G
tinitus 11th October 2012 09:02 AM
Quote:
Originally Posted by agold (https://www.diyaudio.com/forums/equipment-and-tools/221260-soldering-iron-post3195718.html#post3195718)
might depend on where you live
I have a very nice Weller Magnastat for mains voltage
also have a nice gas iron, but ignition needs repair
but I definately could use a solder station
on low budget I find the new RS DS50 very interesting
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
