diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Analog Line Level (https://www.diyaudio.com/forums/analog-line-level/)
-   -   P1 preamplifier (https://www.diyaudio.com/forums/analog-line-level/220824-p1-preamplifier.html)
OnAudio 2nd October 2012 05:48 AM
P1 preamplifier
Here is the P1 preamplifier featuring tone controls. I make no claims rather its smart and handy :D comments welcome
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
OnAudio 2nd October 2012 05:51 AM
Not everybody uses these, that is appreciated. ;) You can swap a 50k pot for the gain control to have both cut and boost thus countering the gain effect of the tone controls. :)
morinix 2nd October 2012 05:56 AM
Nice work horse. Put current sources on the opamp outputs and use a series/shunt regulated supply and it will sing pretty good.
OnAudio 2nd October 2012 06:00 AM
Quote:
Originally Posted by morinix (https://www.diyaudio.com/forums/analog-line-level/220824-p1-preamplifier-post3187013.html#post3187013)
Thank you. Yes class A operation of opamps is quite popular and a regulated supply for them may win the day :)
raul_77 2nd October 2012 08:21 AM
Please. Can you add a 'direct' conmutator for bypass the tones?
OnAudio 2nd October 2012 06:24 PM
Quote:
Originally Posted by raul_77 (https://www.diyaudio.com/forums/analog-line-level/220824-p1-preamplifier-post3187076.html#post3187076)
Thank you. This preamp is very application specific. Bypassing the tones means you are looking for something else, which may also have a better approach :)
The preamp could be expanded to a fully fledged flexible model with the addition of more amplification stages, to cater for balanced in and out and tone bypass and high pass and low pass filter ;) etc or it could be stripped down to an active volume control ;) . But then it would have become something else
morinix 3rd October 2012 07:13 AM
High quality 0.01uf supply filter caps tied as close as possible to the opamp supply pins will help with hf accuracy.
OnAudio 3rd October 2012 05:32 PM
Quote:
Originally Posted by morinix (https://www.diyaudio.com/forums/analog-line-level/220824-p1-preamplifier-post3188328.html#post3188328)
Thank you :) . One could do that, however in light of the input filter and a regulated linear power supply, not forgetting a good source of the chips and good PCB layout, we may get away without them ;) . Yes its a good idea.
morinix 4th October 2012 12:35 AM
PCB trace impedance and inductance be DAMNED! Right?
OnAudio 4th October 2012 02:51 AM
Exploiting trace inductance and resistance has been used for quite sometime now to create electronics that have their extensions in the PCB, to the extent that were you to reproduce that circuit without its PCB it may not work as planned. :)
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
