diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (https://www.diyaudio.com/forums/tubes-valves/)
-   -   Switching SE and balanced inputs/outputs (https://www.diyaudio.com/forums/tubes-valves/219079-switching-se-balanced-inputs-outputs.html)
andyjevans 4th September 2012 09:50 PM
Can somebody point me to different ways (including the simplest!) to lay out a line stage that can accept both SE and balanced inputs and also output both SE and balanced to an amp?
I'm also wondering about different ways to wire up a volume control for this - the usual balanced volume control is between + and -, not + and ground. But how to use that for SE inputs?
The line stage could be either SE or push-pull. Just one stage with an output transformer.
Andy
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
