This is probably very simple for you experienced DIYers but I am a bit confused. I have a Noble 5W resistor with the following label: RGB5 0.33OhmK. Is this 0.33K Ohm resistor or 0.33 Ohm? I am confused by the K at the end. Service manual calls for 0.33 Ohm.
Here is the picture:
PCB with resitor
Thanks.
PCB with resitor
Thanks.
