exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface
exaU2I is the first affordable Asynchronous USB to I2S Interface on the market capable of streaming multichannel 384 kHz and 352.8 kHz DXD in full 32 bit resolution from a PC to a DAC with professional mastering quality. Another groundbreaking first is the support for DFF DSD64/DSD128.
Asynchronous operation is achieved by using fast FPGA control core, 256 kB FIFO memory buffer and proprietary ASIO driver. Galvanic isolation of the I2S output from the FPGA core and the USB ground virtually eliminates jitter and common noise originated by the computer. exaU2I will work with most DIY DAC boards with I2S input. We tested and perfected our design using a DAC based on the ESS Technology ES9018 Sabre32 Reference chip. On the Windows platform the proprietary ASIO driver provides exclusive operation, automatic sampling rate switching and bit-perfect data transfer. Sound streaming is completely independent from the Windows volume control and mixer. Windows WDM / WASAPI support is available by using a third-party native Windows driver - Virtual Audio Cable. We provide two Mac OS X drivers optimised for stereo and multichannel operation. Both drivers support up to 32bit resolution at sampling rates up to 384 kHz. exaU2I Links The original exaU2I thread can be found here. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by
vB Optimise (Pro) -
Copyright ©1999-2019 diyAudio
