diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Analogue Source (https://www.diyaudio.com/forums/analogue-source/)
-   -   May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage (https://www.diyaudio.com/forums/analogue-source/199754-ideas-opamp-lcr-opamp-tube-output-transformer-phono-stage.html)
Witti 3rd November 2011 04:58 AM
Hi
May I have your opinion please. Thank you. :)
https://farm7.static.flickr.com/6032...6d9dbac7_b.jpg
http://www.youtube.com/v/T4wptG4eCTs
http://www.youtube.com/v/xCabYdRFaEo
http://www.youtube.com/v/noZEZDnT0gE
Burnedfingers 3rd November 2011 05:46 PM
I'd love to see schematics.
Sounds good
Frank Berry 3rd November 2011 06:12 PM
Nice sounding phono stage.
Witti 4th November 2011 02:28 AM
Please see schematic. Thanks. :)
https://farm7.static.flickr.com/6240...70f4727d_b.jpg
lcsaszar 4th November 2011 12:09 PM
I have some questions: what is the LCR component between the IC stages? What is the purpose of the tube and the output transformer? (Or what is the purpose of the IC stages, in other words why not full tube or full IC design?)
directdriver 4th November 2011 02:16 PM
Why not add a 10k volume control in front of the tube section and use it as a line preamp to drive your power amp directly. In other words, have the IC section as a stand alone phono stage and the tube section as a line stage. Looks like they are physically separated in your project anyway. The YouTube videos sound nice but where are the shots showing the preamp? Have fun with your project.
Witti 4th November 2011 04:19 PM
Quote:
Originally Posted by oshifis (https://www.diyaudio.com/forums/analogue-source/199754-ideas-opamp-lcr-opamp-tube-output-transformer-phono-stage-post2769596.html#post2769596)
LCR is a RIAA equalization passive network consists of L:inductor C:capacitor and R:resistor. Opamp has some advantages and vacuum tube also has some advantages I would like to get it all so I use both. ;)
Witti 4th November 2011 04:58 PM
Quote:
Originally Posted by directdriver (https://www.diyaudio.com/forums/analogue-source/199754-ideas-opamp-lcr-opamp-tube-output-transformer-phono-stage-post2769730.html#post2769730)
I have already had CD player + pre amp + power amp system and I am new at record playing that is the reason why I built this phono stage. This phono stage consists of both IC and tube section working all together and because of the tube section used to be my headphone amp so you can see them like they are physically separated but it will be finished in one piece box with another piece of power supply box. The sound of YouTube videos was recorded directly from this phono stage to mic port of notebook computer via mini to mini cable (I used a notebook computer to record these videos). Thank you. :D
Witti 10th November 2011 04:18 AM
I am preparing for easily portable version. It will be delivered to my friend's houses for seriously audition test. ^ ^
https://farm7.static.flickr.com/6211...4d907bd8_z.jpg
Bonsai 10th November 2011 08:04 AM
Looks good! Good luck with the audition.
How are things going with te flood by the way?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
