diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Class D (https://www.diyaudio.com/forums/class-d/)
-   -   High power Class D chip solution. (https://www.diyaudio.com/forums/class-d/189200-power-class-chip-solution.html)
nigelwright7557 17th May 2011 09:41 PM
Has any one got any suggestions for a class d chip I can use for high power applications ?
I have used the irs2092 but am not 100% happy with it.
Looking to design 500-2000 watt amplifiers.
MOER 18th May 2011 06:20 AM
High power class D chips
There are no chips available which can withstand > +/-100v and will run at 350-600KHz.
The only chip that we have tried for full range is the IRS21834 but it has a large propagation delay which precludes it from the higher clock.
Our company produces full range high end class D amplifiers for the home and mobile markets.
After much soul searching for a decent high power (>1,000w at 4 ohm) I have moved away from class D and used a class B with a signal tracking supply in addition to a stepped rail switcher. So the efficiency is very high and I do not suffer from the issues of class D amplifiers.
Steve Mantz
Zed Audio
theAnonymous1 18th May 2011 06:41 AM
How about the Tripath TC2000/TC2001/TCA2002?
Power output is only limited by your choice of gate driver and output FETs.
MOER 18th May 2011 06:50 AM
We would not touch tripath with a bargepole.
theAnonymous1 18th May 2011 07:22 AM
Quote:
Originally Posted by MOER (https://www.diyaudio.com/forums/class-d/189200-power-class-chip-solution-post2575589.html#post2575589)
Yes well, you are not the one who is asking for suggestions either.
BTW, my dream TCA2002 design would use IX6R11S6 + IRFP4227.
TheDealer 18th May 2011 11:39 AM
Quote:
Originally Posted by theAnonymous1 (https://www.diyaudio.com/forums/class-d/189200-power-class-chip-solution-post2575603.html#post2575603)
What is the main difference for example to the TA3020 ? I know that this chip can drive MOS-FETs up to 300 W per channel. Is it a controller + powerchip in one unit and the TCA2002 only a controller ?
theAnonymous1 18th May 2011 01:11 PM
Quote:
Originally Posted by TheDealer (https://www.diyaudio.com/forums/class-d/189200-power-class-chip-solution-post2575734.html#post2575734)
Because of the gate driver that's built in to the TA3020, it has a max supply limit of +/-65V.
The TC(A)200x is just a controller/modulator, so the max supply voltage for a design based on this IC will only be limited by the chosen gate driver and FETs.
TheDealer 18th May 2011 01:26 PM
Quote:
Originally Posted by theAnonymous1 (https://www.diyaudio.com/forums/class-d/189200-power-class-chip-solution-post2575817.html#post2575817)
Thanks much. O.K. this means more design space for the the TC(A) units.
Hope also to realize one day a hit powerful amp with one of these Tripaths.
carvinguy 18th May 2011 08:07 PM
I'm curious if anyone has looked at these class-D drivers from Silicon Labs. Haven't seen anyone using these yet.
Supplies can be up to +/-750V:eek: and adjustable dead time down to less than a nS. Still, you need to provide the modulator and all protections.
luka 18th May 2011 09:07 PM
damn.... that would be crazy, and they can go up to 8MHz?!?!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
