diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Multi-Way (https://www.diyaudio.com/forums/multi-way/)
-   -   What has been the most detailed driver you have worked with? (https://www.diyaudio.com/forums/multi-way/187188-detailed-driver.html)
JZatopa 16th April 2011 07:22 PM
I'm curious what you guys have found to be the most detailed driver you have used?
Helmuth 16th April 2011 10:56 PM
Quote:
Originally Posted by DJNUBZ (https://www.diyaudio.com/forums/multi-way/187188-detailed-driver-post2540748.html#post2540748)
Mid Visaton TI100.
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Low monacor sph250ctc.
MONACOR INTERNATIONAL : New products
High DT300.
pinkmouse 16th April 2011 11:11 PM
Audax HM100Z0.
Dr_EM 17th April 2011 11:33 AM
Quote:
Originally Posted by pinkmouse (https://www.diyaudio.com/forums/multi-way/187188-detailed-driver-post2540928.html#post2540928)
Audax HM100Z0.
Ah yes, there is something a bit special about them. I do wonder if maybe I shouldn't have sold mine. They just need to be treated very carefully with regard to their enclosure and I didn't give them enough room to breathe. They still produced incredible imaging though.
Well, looks like they are back in production again anyhow, can get new models from Madisound which are presumably identical to the originals.
Helmuth 17th April 2011 02:03 PM
Quote:
Originally Posted by Dr.EM (https://www.diyaudio.com/forums/multi-way/187188-detailed-driver-post2541279.html#post2541279)
My TI100 are 4" to like the audax I think it is a good diameter for open sounding mid-reproduction.
bear 17th April 2011 03:24 PM
What exactly does that mean?? "detailed"??
Lowest distortion?
Widest bandwidth?
Flattest in band response??
Tip up the highs and people think it is "detailed".
Not much of a trick in that. Works most of the time.
The best single driver I have ever worked with that is not on a horn was the Stage Accompany ribbon... probably because it was nearly flat, very wide bandwidth (it went flat past 20kHz.. - not that many can hear up there) and it was lower in distortion by an order of magnitude compared with other very good direct radiator drivers of any type... It did have vertical dispersion issues however... so no free lunch (yet). FYI usable range was from 1.5kHz. up.
So there is my "2 cents worth" of personal preferences and opinion... and as always, I am always right. :D
_-_-bear
Cal Weldon 17th April 2011 03:32 PM
Coral's holey version of the Fostex 103 sold under the Monarch name, 16 ohm, alnico mag.
SY 17th April 2011 03:48 PM
Audax HM100Z0.
Took the words out of my mouth, assuming we're limiting ourselves to dynamic magnetic drivers. If we don't, then there's the Hill and Ionovac drivers...
jerome69 17th April 2011 03:58 PM
SEAS excel magnesium
StigErik 17th April 2011 04:10 PM
Without any doubt: B&G RD-75
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
