diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Analog Line Level (https://www.diyaudio.com/forums/analog-line-level/)
-   -   EAD theatermaster 8800 problem (https://www.diyaudio.com/forums/analog-line-level/183835-ead-theatermaster-8800-a.html)
alexbeni 24th February 2011 11:32 AM
Hai, my theatermaster 8800 suddenly turnoff from standby mode just like you unplug the power cord!, I didn't have chance to look inside the cabinet yet (still looking for special screwdriver), I think the fuse is blown!, anybody have the same experiance with this mater?, is there any other potensial problem except the fuse?
many thanks
alexbeni 4th March 2011 08:14 AM
Yap, Its the internal fuse blown, any body have sugestion how this could hapened?, is there any particular component that I should check before changing the fuse?
thanks
PTsomokos 25th March 2011 09:59 PM
Maybe its nothing. Its very often fuses blow up after several years because they are just old. Change it with no hesitation with a ''slow blow'' one. If its blow again then you have a problem
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
