diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Digital Line Level (https://www.diyaudio.com/forums/digital-line-level/)
-   -   DCX2496 "extra" settings to improve XO designed with it? (https://www.diyaudio.com/forums/digital-line-level/166270-dcx2496-extra-settings-improve-xo-designed.html)
doug20 3rd May 2010 10:57 PM
I believe there was a thread on how some "extra" DCX settings would improve the XO created on it.
I thought I saved the link but i can not find it anywhere now. I have also searched for the past hour
Maybe I was imagining it? :(
btw, Im not talking about DCX hardware modifications or DCX gain structure issues.
boconnor 4th May 2010 08:59 AM
Quote:
Originally Posted by doug20 (https://www.diyaudio.com/forums/digital-line-level/166270-dcx2496-extra-settings-improve-xo-designed-post2174824.html#post2174824)
I believe there was a thread on how some "extra" DCX settings would improve the XO created on it. I thought I saved the link but i can not find it anywhere now. I have also searched for the past hour Maybe I was imagining it? :(
I'm not sure what "extras" you mean but I'm currently experimenting with the parametric eq settings to even out the response of an active three way system.
I'm using Audiolense to do the in-room measurements then varying the eq's Q (bandwidth) and frequency centers in each channel, and varying the individual channel gains, to smooth out the 1/3 octave curves.
David_Web 4th May 2010 09:48 AM
Was it this?
http://www.diyaudio.com/forums/multi...tml#post726684
http://www.diyaudio.com/forums/multi...tml#post726747
DougL 4th May 2010 03:11 PM
The other thing that seems to help is the digital delay function.
I delay the mid and tweeter the approximate distance of the woofer as a starting point.
The effect is subtle and may be an illusion. YMMV.
HTH
Doug
Pano 4th May 2010 04:58 PM
Not an illusion at all. :) The delay is important and so easy to do, why not use it?
It's all about phase, really. The physical offset of the drivers is just a starting point. The driver+filter response will change the phase.
With a decent measurement setup you can see the phase at the crossover point and then adjust polarity and delay to get your drivers to match at the crossover point. This can make a big difference to depth and stereo imaging.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
