diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (https://www.diyaudio.com/forums/tubes-valves/)
-   -   Freds in 6X5 psu? (https://www.diyaudio.com/forums/tubes-valves/164555-freds-6x5-psu.html)
Brit01 5th April 2010 05:40 PM
Freds in 6X5 psu?
I'm referring to Bas's Hornemans psu for the Aikido. Don't have the schematic handy at this moment but I'm sure most of you know it.
It has 2 diodes and an 6X5.
Just wondering if a couple of Freds in place of the standard diodes would make any improvement here.
Soonerorlater 5th April 2010 06:14 PM
H Brit01,
According to my schematic (version 1), it states that you use 600v 1a fast diodes presumably instead of standard ones.
HTH Bill
Soonerorlater 5th April 2010 06:28 PM
Hi Brit01,
Just wondering if a couple of standard diodes in place of the Freds would make any difference at all here.
Is the necessity of using fast diodes instead of standard ones the issue your really getting at
Brgds Bill
Brit01 5th April 2010 06:43 PM
HTH Bill
I was using 1N4007's.
I might give the FREDs a go then. Not sure if it will make a noticeable difference but always like to experiment.
Thxs
Soonerorlater 5th April 2010 06:57 PM
Normally I would go for Freds, UF4007'S etc instead of IN4007's to avoid switching noise.
I'm not sure though what happens to switching noise in a Graetz bridge, perhaps someone more knowledgeable could comment on this.
Brgds Bill
Eli Duttman 6th April 2010 01:12 AM
Performance of a hybrid bridge rectifier is dominated by the vacuum diodes. SS diode switching noise is blocked from entering the B+ rail. The reason for using good SS diodes is to ensure switching noise doesn't sneak into the signal path via the heater supply. UF4007s are easily snubbed into near silence (parallel with 10 nF. high WVDC caps.) and are quite inexpensive. There's no need to pay for FREDs or deal with the mechanical issues TO220 cases present.
Soonerorlater 6th April 2010 10:39 AM
Eli D.
Many thanks for your concise reply.
Brgds Bill :)
Brit01 6th April 2010 01:39 PM
Thxs Eli.
I've already got some FRED's in stock so no harm in experimenting I guess.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
