diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Swap Meet (https://www.diyaudio.com/forums/swap-meet/)
-   -   FS:ultimate attenuator kit for audio,balanced/single-end (https://www.diyaudio.com/forums/swap-meet/163454-fs-ultimate-attenuator-kit-audio-balanced-single.html)
bbp 19th March 2010 11:10 AM
3 Attachment(s)
This is a great KIT for those DIYers who want to build high-end quality audio DIY projects. It based on the following highlights:
R-2R current switching technology
High precision SMD resistors
High performance Analog switches DG413DY
Ultra-high performance Op-Amp AD797AR
Ultra-pure voltage regulator on board
Ultra-low noise
Ultra-low distortion
Low output impedance
Micro-controller with remote handset
4 input sources selectable
Wide range attenuation -96dB~0dB in 1dB/step
With this KIT, you can build a HI-END preamplifier easily ^_^
Price :
$250 single-end stereo
$450 balanced stereo
paypal accepted
airmail registered included
More information about my KITs ^_^
http://www.diyaudio.com/forums/swap-...ontrol-v2.html
http://www.diyaudio.com/forums/swap-...r-10-sets.html
http://www.diyaudio.com/forums/swap-...ntrol-kit.html
https://www.diyaudio.com/forums/atta...1&d=1268996959
USER MANUAL is ready, drop me an email ^_^
bbp6604560 at hotmail.com
orthoaudio at hotmail.com
thanks
bbp 19th March 2010 11:17 AM
information added
THD+N VS OUTPUT AMPLITUDE
https://www.diyaudio.com/forums/atta...1&d=1268997374
FFT @-20dBV
Frequency Response
CustomHT 19th March 2010 11:54 PM
Is one of the inputs a bypass input(signal in will be uneffected by volume control) so It can be used as a home theater-bypass??
bbp 20th March 2010 12:33 AM
Quote:
Originally Posted by CustomHT (https://www.diyaudio.com/forums/swap-meet/163454-fs-ultimate-attenuator-kit-audio-balanced-single-post2125225.html#post2125225)
sorry CustomHT, I reserved no bypass input,because the volume control is excellent enough for any audio applications ^_^
the input voltage range up to 10Vrms when you set the attenuation to 0dB,the module still provides low distortion signal
and even it accept 20Vrms input signal when you set the attenuation to -20dB
I most applications,the module can be deemed to a straight line when you set the volume attenuation to 0 dB
maybe a pass through is the best, but maybe w/o a pass through is no the matter ^_^
thank you
bbp 21st March 2010 03:07 AM
w/o any capacitor in the audio signal
assembled kit
needs only addtional DC PSU +14/-14 @ 0.2A
easy to setup
bbp 9th April 2010 09:51 AM
Only balanced version available now
jtktam 9th April 2010 07:37 PM
would a chassis be available for this?
-joe
bbp 10th April 2010 01:07 AM
Quote:
Originally Posted by jtktam (https://www.diyaudio.com/forums/swap-meet/163454-fs-ultimate-attenuator-kit-audio-balanced-single-post2148346.html#post2148346)
-joe
Hi Joe,
Maybe later the chassis is available, but I think to ship a aluminium chassis from HK to wordwide cost may a lot >_<
regards
Lu
bbp 17th April 2010 01:42 AM
New remote handset
1 Attachment(s)
aluminium remote handset updated
https://www.diyaudio.com/forums/atta...1&d=1271468512
bbp 22nd April 2010 09:06 AM
test performance added
1 Attachment(s)
Test result added
fully THD+N VS AMPLITUDE test
750 ohm loaded @ each phase of balanced
A-weighting
1mV to 16Vrms sweep
the blue line is the Residual performance
the green line shows the performance of this KIT
https://www.diyaudio.com/forums/atta...1&d=1271926938
the gragh shows that the THD+N of R-2R VCS KIT is -110dB@5Vrms,only 1uV residual noise!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
