diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Class D (https://www.diyaudio.com/forums/class-d/)
-   -   Any input on the new Dayton TK2050? (https://www.diyaudio.com/forums/class-d/162378-input-dayton-tk2050.html)
finnbow 2nd March 2010 12:21 AM
This sounds like a pretty good deal to me (when/if they get it in). Any input, advice or experience with this TK2050 amp and accessories?
https://i837.photobucket.com/albums/...0-383_sIII.jpg
von Ah 2nd March 2010 04:03 PM
Bump for me, too! :D I'm hoping this package will be great stock, and will be able to accept some of the more influential mods from the big Tk2050 thread...
sendler 3rd March 2010 12:39 AM
Dayton TK2050
Quote:
Originally Posted by finnbow (https://www.diyaudio.com/forums/class-d/162378-input-dayton-tk2050-post2103668.html#post2103668)
Looks cool. Thanks for the tip. I am CRAZY about my modified Sure 2X100 amps which run the TK2050 chip set. I just ordered 10 more so I will have plenty ready as I move forward on my PC cross 4 ways.
finnbow 3rd March 2010 03:06 AM
FYI, I inquired at PE today and they're expecting the first batch of these on 4/20. They also do not have any further technical info available.
planet10 3rd March 2010 03:19 AM
I wonder if those 4mm outputs are 3/4" apart?
dave
SoldierAnt76 24th March 2010 04:43 PM
In Stock
Looks like these units are shipping. I just received a tracking number, and the product page now says "in stock."
dr_vega 24th March 2010 08:02 PM
Quote:
Originally Posted by SoldierAnt76 (https://www.diyaudio.com/forums/class-d/162378-input-dayton-tk2050-post2130026.html#post2130026)
They don't say, but it looks like they only have one power chip, which pretty much limits them to 8 ohm speakers. And the 24v brick is nothing to write home about.
The Sure with a Meanwell power supply for the same money seems like a much better deal. You just need to find a box.
-cc
SoldierAnt76 24th March 2010 09:08 PM
Dta-100
True, but the average person doesn't have the time, skill, or inclination to build and troubleshoot an amp (even a prefabricated Sure board). And it's easier to recommend a finished product to friends and family.
I suspect one of the biggest obstacles to wider Class-T adoption is the fact that most finished amps fall into one of two categories: 1) inexpensive but barely powerful enough for an "ordinary" set of speakers (e.g., TA2024, TA2020), 2) powerful but expensive (e.g., Virtue One). A TK2050 amp like the DTA-100 is a middle ground between these two extremes.
Jack Caldwell 2nd May 2011 11:28 PM
I had one of these...
Hi, I had one of these units. Some comments:
1) Performed very well, pretty good sound and a decent smps.
2) Not as good as the Virtue by any means, but much better than pretty much any receiver or even other chip-amps like the ones based on the National Semi sets.
3) If you want to mod it, it's going to be difficult due to the size of the package.
4) Easiest mod would be to outboard the coupling cap.
5) It's true this Dayton amp does NOT like 4 ohm loads. For that go to the hifimediy or Sure boards and build yer own... or get a Virtue which is a really, really great amp.
But for a quick and easy solution for 8 ohm speakers, especially if they are efficient, the Dayton is very pleasing to the ear.
Jack Caldwell 2nd May 2011 11:29 PM
Quote:
Originally Posted by planet10 (https://www.diyaudio.com/forums/class-d/162378-input-dayton-tk2050-post2105202.html#post2105202)
dave
Yes, they are, takes a standard width dual banana.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
