diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Multi-Way (https://www.diyaudio.com/forums/multi-way/)
-   -   Arta Asio (https://www.diyaudio.com/forums/multi-way/144282-arta-asio.html)
doylep 17th May 2009 12:28 PM
Arta Asio
I have search far and wide for arta support on this one this is a last resort. I have a full registered version of ARTA 1.5. The software is as advertised in many forums 'amazing for the price' I was using this with an m-audiophile 2496 with great results using particulary with FR2 measurements.
Anyhow I have recently upgraded to the m-audio firepro 610, the WDM driver has minimal support whereby you cannot record from the line-in only mic/instrument in. The ASIO driver provides full access to the 6 inputs of the profire however ARTA does not support asio drivers I think ?
My question is, has anyone had any success with asio drivers using ARTA ? (I succpect not)
Does anyone know how to request this of the ARTA developers ?
Can anyone suggest alternative sw that does support ASIO with comparable function to ARTA.
Thanks in advance for any response.
cuibono 17th May 2009 01:42 PM
If ARTA doesn't support ASIO, try the program asio4all, it might help.
doylep 18th May 2009 05:01 PM
Thanks for the response however asio4all simulates an asio driver for software that requires asio drivers and your hardware only has WDM drivers. what I need is the reverse, I have an asio driver however the software (ARTA) does not support ASIO drivers.
I am corresponding with ARTA at the moment so I am hopeful of a solution.
domtw 19th May 2009 12:40 AM
Please, share the solution with us when you have it...
doylep 19th May 2009 03:11 PM
Ok, I got the solution at least for the profire 610, Here is a full description and solution to the problem.
here is my setup In Breif
HP Laptop 2GHz DC 3.2 Gb Ram
WinXP Pro SP3
Internal Texas 1394a firewire
Mic
EarthWorks M30
Voltage divider: as per standard design
R1 8200 ohm
R2 910 ohm
R5 700 ohm
Now I have the M30 input into 1st pre and sw1 return routed to output 7 and onto the amp then to the DUT.
This works fine for FR1 type measurements and I see fr response as expected.
But no good for FR2
Now what I had hoped to do was to connect the amp probe reference signal to the line input of the profire (3/4) however ARTA does not see these inputs with the WDM driver. I have since learnt then the WDM driver ‘profire610multi’ is a very limited and only provides inputs for pre 1&2 and sw1,2 returns. Hence my question on the support for ASIO that is fully assignable to all ins/outs.
I was reluctant to feed the amp probe reference into the second pre as I had thought the signal would be too high and may damage the pre. Although upon reading the specs the pre can handle signal ranging from +14.5dBV to -39dBV (there is also a 20dB pad)
So I gave it a go and all is working fine now, LIMP is also functioning through the mic/inst inputs.
I think the voltage probe may need some tuning as the instrument input is rated at 1M ohm.
Ivo from ARTA was very responsive to my issue and helped resolve it. I can fully reccomend this software and the support well worth the licence cost.
Whilst ARTA does not support ASIO now Ivo indicated it may be implemented in the next release.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
