I've got a couple things in mind, but for the sake of argument let's analyze this one:
Hi Labrat,
If you are unsure, the safest way would be to parallel R1 (1M) with a 100k resistor and feed the signal directly to the connection where originally the wiper went (junction of 100k, 1M and 100R resistors).
This way your amp still has ~100k input impedance.
If I understand the basics right, leaving the input open (without the 100k resistor) would increase your input impedance (mostly determined by R1=1M). In most cases that might not be a problem but I am always scared of picking up RF if the input impedance is too high.
My 1 1/2 cents worth...
Martin
Martin
- Tubes / Valves
- Bypassing a volume pot
