diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Chip Amps (https://www.diyaudio.com/forums/chip-amps/)
-   -   Tube-Buffered Gainclone (https://www.diyaudio.com/forums/chip-amps/124094-tube-buffered-gainclone.html)
sorenj07 31st May 2008 08:37 PM
Hi, first post in this neck of the woods :) I've got a 2x30V 300VA Hammond toroid kicking around. Would it be suitable for building a gainclone using the standard LM3875T chips? I usually see secondaries around 18-22V being used. I would probably have a rail voltage of around +- 42V. On the other hand, I could wire the dual primaries in series to put out +-21V or so, but this seems a little low... Speakers used would be 8 ohms.
Does anyone happen to know the input impedance of the LM3875 by the way? It'd be useful in designing the cathode follower which would feed the volume control.
Greg Erskine 31st May 2008 08:43 PM
http://www.national.com/ds/LM/LM3875.pdf
sorenj07 31st May 2008 09:06 PM
Am I right in assuming, then, that 42V will be ok into 8 ohms since it's well under the maximum rating of 80V or so? I'm new to these "solid state" things :smash: I assume I should try to mount them to a heatsink, right?
ionomolo 31st May 2008 11:01 PM
Quote:
Originally posted by sorenj07Am I right in assuming, then, that 42V will be ok into 8 ohms since it's well under the maximum rating of 80V or so? I'm new to these "solid state" things I assume I should try to mount them to a heatsink, right?
Yes, you need a big one! there is an application note on heatsinking national amplifiers and some information on the datasheet.
sorenj07 31st May 2008 11:06 PM
All right. Do you think some CPU style heatsinks with a mounted fan would work all right? I have no clue about dissipation ratings and the like, but I will take another look at the datasheet. It's just so long :eek:
Nordic 31st May 2008 11:33 PM
Not a chance.... They dissipate about 60W with fans blowing like mad. If at all possible issolate the heatsink from the case, then mount the chip useing only a little thermal grease... but you are going to need a much sturdier sink than that...
sorenj07 1st June 2008 12:25 AM
There are some interesting-looking options for the tweaker market..
http://www.newegg.com/Product/Produc...page=1&bop=And
Either some of the more crazy ones, or I start looking for massive blocks. Pity, I figured that these chips wouldn't need that much sinking.
DC Dave 1st June 2008 12:55 AM
Wait a minute.
That is going to be to high. 42+42=84V. The 80V maximum referred to is the sum of the + and -. You are going to want a lower voltage for that chip.
Zigis 1st June 2008 01:12 AM
With this trafo you can use regulated PS, to regulate voltage down.
http://www.diyaudio.com/forums/showt...106&highlight=
sorenj07 1st June 2008 06:58 PM
Hey, looks perfect!
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
What do you make of using the following schem for the signal part?
http://www.geocities.com/rjm003.geo/...io/diy_gc.html
specifically, this:
Or should I just use the textbook example from the datasheet, under "Typical Application"? Anyone have any recommendations?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
