diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Solid State (https://www.diyaudio.com/forums/solid-state/)
-   -   Wanted JLH Class A Phone Amp Pcb overlay (https://www.diyaudio.com/forums/solid-state/11330-jlh-class-phone-amp-pcb-overlay.html)
colin.hepburn2 19th February 2003 12:09 AM
Hi can some one help and let me have A PCB overlay for the JLH Headphone Single ended class amp Circuit 2 found at the class and Amp Site
http://www.gmweb.btinternet.co.uk/index.htm#index
chris ma 20th February 2003 02:42 PM
Colin,
Have you thought about doing it with point to point rather, if there is no such pcb layout avilable?
Chris
colin.hepburn2 21st February 2003 08:48 PM
JLH Class a Phone Amp
Hi Chris
Thank you for the reply my request for wanting the Pcb Overlay Is really down to my nolage of electronics which is a bit thin when the component count starts to get larger this is why I mostly builds Kits with PCB supplied
As this is much easer for me to follow I am building a cascade single ended 45 Watt pre+ power Amp Known as the apex Amp Designed by Graham Nalty of Soniclink Cables
I Was thinking that I would have a go at the JLH, head Phone Amp if some one had the pcb overlay, But at the end of the day my goal is to build the JLH Class A Amp Of which you Kindly supplied the PCB Overlay
Colin
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
