diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Multi-Way (https://www.diyaudio.com/forums/multi-way/)
-   -   SEAS 27TBFC curiosity (https://www.diyaudio.com/forums/multi-way/112097-seas-27tbfc-curiosity.html)
PeteMcK 18th November 2007 05:31 AM
While attempting to clean what I thought was speck of dust from the grill of one of my 27TBFCs, it appears that there is a clear plastic disk covering the centre of the grid (on the inside)...???
I know my eyesight is on the way out, but I don't think it's that bad, can anyone confirm that theirs are the same?
I suppose this will make a difference to the dispersion if anyone removes the grid... (I'm still very happy with these drivers, not complaining).
owdi 18th November 2007 06:28 AM
Mine also have the clear plastic disc below the grid. I believe it helps improve top end off axis response.
Dan
Jon Paulsen 18th November 2007 03:34 PM
The plastic lense or diffusor is there to lift the frequency response between 15 and 20kHz
Dave Bullet 18th November 2007 08:47 PM
I see the same on mine. Although I haven't taken the grille off, when angled under sunlight, looks like the dome itself has a "flat spot" in the centre - which is a hexagonal shape.
Good to have that explanation.
Thanks,
David.
sreten 19th November 2007 10:45 AM
Quote:
Not really. It improves the dispersion characteristics, which are very good.
:)/sreten.
Jon Paulsen 19th November 2007 02:23 PM
Hi Sreten
That is a consequence. I was involved in the development of the disc at that time and did most of the measurements.
Jon
SEAS
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
