I've this bunch of PCF80 (same as ECF80, 6BL8) laying around and I know some little things can be done with them. Up till now, I gathered some schematics and spent some time understanding them (back to paper since I can't figure how to use tubes models with LTspice). Still, I've been wondering if a smallish headphones amp couldn't be done with those tubes. With two tubes, I can get a triode for gain, a triode as phase splitter. Up till there, I can understand how it works (very basic understanding...).
A long introduction to just say I'm stuck understanding how much power I could get from the pentodes of the pcf80, triode strapped and used push-pull, into 300 ohms. I see that at 120VDC, I won't destroy the tubes if I ask for 14mA. But can I get those 14mA or not ? I've also a hard time understanding how much voltage swing I can get at the output.
I would really be grateful if someone could point me towards references on this (I found a lot of things on tubecad.com but it goes a bit quickly over the "obvious" things a newbie like me is still missing).
Thanks a lot,
Ben.
(Otherwise, i could of course parallel a bunch of triodes as SE cathode followers with the pentodes as sink).
Thanks a lot,
Ben.
edit: here are the curves for the triode strapped pcf80: http://www.tubes.mynetcologne.de/roehren/daten/ecf80pentode_as_triode.pdf
Ok, the PCF80 pentode once triode strapped looks a bit like an ECC81. So, I could do some sims and the schematic below seems to work.
I've just one question: how to properly set C4 and C5 ? Values around 10µF seem ok in sims but I don't trust LTspice too much.
