diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Digital Source (https://www.diyaudio.com/forums/digital-source/)
-   -   Capacitors for digital circuits- Tants vs electrolytics (https://www.diyaudio.com/forums/digital-source/11054-capacitors-digital-circuits-tants-vs-electrolytics.html)
Dr.H 12th February 2003 05:01 AM
Hi All,
What is an optimal cap for digital circuitry? I have seen suggestions to:
1. Use tantalum caps since they "ring" (not audible of course) less when in use
2. Or use very large (1000uF) Panasonic FC or FA caps for local decoupling
3. Use a combination of cpas for decoupling (ala Pete Goudreau)
There would appear to be merit in both 1 and 3, but I am not so sure about 2.
Any comments?
Ryan
fmak 12th February 2003 07:10 AM
Re: Capacitors for digital circuits- Tants vs electrolytics
[QUOTE]Originally posted by Dr.H
[B]Hi All,
OSCons are quite small and have very low impedance and good frequency characteristics. I find them excellent as digital bypasses etc.
I have used tantalum extensively when there is no space or when there are cost limits, especially in power supplies. Their high distortion does not seem to matter.
Large lyics have poor high frequency characteresitics despite claims to the contrary. To me, they are just too large to force fit on SMT boards.
SMT caps are best as parallel bypasses to arger caps.
CheffDeGaar 12th February 2003 08:44 AM
Heavy thread here, but worth reading :cool:. Not very easy to navigate through the multiple curves, but in conclusion, it appears that a cheap Panasonic 100uF FC paralleled with a high value (4.7uF) SMT ceramic from Murata, plus some small SMT ceramics do a good job.
Hope this helps
fmak 12th February 2003 08:54 AM
Quote:
Hope this helps
Unless ones designs the PCBs from scratch, most of the time it is not possible, or very messy to do this
jackinnj 12th February 2003 01:02 PM
decouple all the power supply pins with 100Nf ceramic. for ADC's I use a 4.7uF tantalum with a 100Nf ceramic. I surround the ADC with a ground plane. A decoupling cap without a ground plane is about as useful as the tits on a bull.
tiroth 12th February 2003 01:22 PM
Ever tried a big (3-10uF X5R) ceramic in place of the tantalum? I would think it a lot better there. I don't have the equipment to measure it though.
ALW 12th February 2003 03:11 PM
Decoupling
I'd second the use of OS-CONs they are really good.
As a cheaper alternative the Rubycon ZA's are excellent, reaching minimum, and close to organic semiconductor cap levels, at around 100-150kHz.
You can then bypass with a suitable HF cap (ceramic / PPS) to take over from here - surface mounts are ideal for fitting across existing cap leads, on the underside of a PCB.
Andy.
Peter Daniel 12th February 2003 03:21 PM
Here's the link to the similar mods I did on my DAC http://www.diyaudio.com/forums/showt...mods+never+end
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
