diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (https://www.diyaudio.com/forums/tubes-valves/)
-   -   Diode Heatsink (https://www.diyaudio.com/forums/tubes-valves/106608-diode-heatsink.html)
dmk 9th August 2007 02:51 PM
Diode Heatsink
Hi all,
I am building an Aikido Pre-Amp and am going to use solid state rectification. I am planning on attatching diodes to a heatsink which will then be mounted on top plate of chassis along with TX's, Caps, Choke etc. Will mounting the heatsink on top plate be ok? Likely to cause any problems?
Cheers
Dave:confused:
jan.didden 9th August 2007 02:53 PM
Re: Diode Heatsink
Quote:
Originally posted by dmk
Hi all,
Cheers
Dave:confused:
You probably want to make sure the diode anode as well as the cathode are insulated from the chassis. What's the diode physical appearance?
Jan Didden
dmk 9th August 2007 03:15 PM
Hi Janneman,
I was looking to use TO-220 - On Semi MUR860 type.
Cheers
Dave
leadbelly 9th August 2007 03:21 PM
Hi Janneman,
Cheers
Dave
IMHO, that a bad choice. A 600V PIV is low for what I am assuming is a 240V secondary, and it's a non-isolated package, so you'll have to use insulators to mount it to your top plate. A messy solution, fraught with maintenance hazards.
jan.didden 9th August 2007 06:25 PM
Yes, 240VAC gives a peak of square-root of 2 * 240 = about 340V. So, if the AC goes max negative (-340) and the cap is at +340, the diode gets almost 700V. I would take at least 800, preferably 1000V diode.
Jan Didden
dsavitsk 9th August 2007 08:29 PM
Re: Diode Heatsink
Why? Isn't the heat dissipated essentially the current multiplied by the voltage dropped? Both of those are low here -- I'd skip the heatsink.
dmk 11th August 2007 02:37 PM
Hi
Thanks for the replies, I will use another type of Diode and do
away with the Heatsink. Which Diode would you recommend?
I am aiming for 300VDC.
Cheers
Dave
Renron 9th September 2007 03:34 PM
Try this one!
I am building an Aikido Preamp with ecc802s tubes (12au7)
I found this diode for rectification. Ultra fast soft recovery type.
read this thread for more info. 1000v 4A
DIYAUDIO thread
Mouser has them for $0.66 ea. Gotta love that price!
Good luck with your project.
Ron
Renron 9th September 2007 04:03 PM
Sorry, not too much info on that link.. shoulda read it completely first. My bad.........
Maybe try a Fairchild Stealth diode, some people are reporting good success with them and they can be had in 1200V 8A To-220 package from Mouser for $1.95
I may just go that route instead of the Mur4100e as the FS do not need snubbers to keep them ultra quiet. (as reported, but not by me) (I have no practical experience with either of them)
FS stealth diode
Ron
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
