E/I does not equal L. E/Ima=L. Do not convert Ima to a.OK, but have in mind that when accidentally the net final value coincide, mathematically IS NOT the same. Conceptually, to considerate that E/I = L, is a severe misunderstanding of Physics.
2000v/1000ma= 2h, 2000v/1a=2000ohms
That's wrong. As inductance is not equal to resistance, the reactive value of the impedance of an inductor is equal to a certain value of resistance only at one frequency. But in such a case, phase angle is 90° between them.
Please, take a reading at electricity basics, for your convenience.
The attached is a photograph of the text which gives the formula. It is from ARRL handbook 1972 printing. It is also copied verbatim in the 1980 version. One would think that if it were wrong, it would have been corrected some time in the 8 years between the two printings. No?
You should not regard ARRL (or RSGB) publications as being totally reliable in technical matters. They simplify things, sometimes too far. Whether they do this to aid their readers, or because the writers do not always fully understand, is not clear to me. Most radio amateurs are allergic to maths and physics. (Dave G8HQP)
- Power Supplies
- Minimum current for choke operation
