NAD 7020i - DOA
NAD 7020i - DOA
Thread Tools
Old 26th September 2021, 07:55 PM   #61
indianajo is offline indianajo  United States
indianajo's Avatar
Manual is in post #2.
Dynakit ST70, ST120 (modified), PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800s, M-2600, MMA-875T, SP2 (2004) speaker, PV8 mixer, Herald RA88a mixer (modified), Steinway console, Wurlitzer 4500, 4300
Old 27th September 2021, 10:20 AM   #62
DonaldStott is offline DonaldStott  Scotland
I previously downloaded and searched through all the manuals linked to in Post #2 above.
But as several Forum members have noted, there are no Secondary AC voltages shown on the NAD circuit diagrams/schematics.
Old 27th September 2021, 11:05 AM   #63
MikePP is offline MikePP
I haven't followed this thread for a day or so due travelling after a holiday
Just to clarify, I spotted on the 7020i manual there were two 120 primarys (one with a tap for 110), so that would say there should be 5 wires coming from the primary side
If there's six then it could be an undocumented thermal fuse connection that's now blown and O/C, but I couldn't quite see that from the photo's (which have now disappeared anyway?!)
If there are indeed six wires from the primary then I suggest emulating the blown thermal fuse by bridging at the pcb to regain the ~16ohms total primary impedance. The amp (if no faults) should now power up for you to check AC secondarys
I'm not suggesting return to customer in this state , but it would give you opportunity to get the secondary voltages (and currents if you break each winding in turn to measure current)
As for working out the secondarys without the TX working , one could simply work back from the DC levels on each rail, give a bit of headroom and bingo you have your AC secondarys. (and if you know the secondary DC values you can rig up a PSU to gauge current requirements needed.)
Heck I'm even run a dual primary on one of it's intact 120 windings on a variac (when one was damaged) to get the secondarys in the past.
I wouldn't bother with it personally but that's just me
Old 27th September 2021, 03:04 PM   #64
The Primary connections and their associated colours are shown in the attachment to Post #45 by ALAN4411.
We have established that any fault probably lies with the BLACK wire - there is no chance of repairing this Primary as it is usually the first winding on the bobbin.
Old 27th September 2021, 04:24 PM   #65
indianajo's Avatar
DC voltage of full wave rectifier is (1.4*Vac)-1.4 v.
DC voltage of half wave rectifier is (1.4*Vac)-.7v
They may run some windings hard so a little higher on the AC voltage.
Old 23rd October 2021, 12:25 PM   #66
Default Transformer Disassembly
Various stages of the NAD 7020i transformer disassembly:-
And a close-up view of the Primary connections:-
With the expert help of Forum Member Alan4411 we've deduced that the BLACK wire, the only one with an internal connection problem, must be linked to a thermal cut-off or fuse of some type?
  Reply to this post
NAD 7020i - DOAHide this!Advertise here!
Thread Tools
NAD 7020i sudden death zenzaman Solid State 192 14th February 2021 06:04 PM
KSA 200B - E-Bay sort of DOA amper Solid State 0 21st June 2010 02:33 AM
"Manage Attachments" DOA c2cthomas Forum Problems 1 15th January 2010 03:27 AM
4 pin to TOA gonna drive me to DOA fretknowmore Analogue Source 1 11th December 2009 10:28 PM
NAD 7020i - pre-amp power supply issue mashley_nad Solid State 6 29th May 2009 04:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
