Help with replacing capacitors and voltage regulators
Thread Tools
Old 14th September 2021, 04:57 PM   #31
wiseoldtech is offline wiseoldtech  United States
wiseoldtech's Avatar
Originally Posted by jean-paul View Post
Eh always is a little depending on what insulation sheet is used. So no show of the goods = no good info in return.
And the saga of the Mystery Amplifier continues....
Bohemian Guru sagacious, professional.
Old 15th September 2021, 01:02 AM   #32
RandomAudioGuy is offline RandomAudioGuy
Always. Use just a very tiny bit. I am a bit worried you don't know... Also drill 6 mm holes for better air flow in the PCB when possible. Tip: don't drill where there are PCB tracks Better airflow is always OK, less heat is also always OK. There is no such thing a too good cooling/heat disposal.
It was suggested to check WHY the heat occurs and to check the difference in input and output voltage. Is the heat unavoidable (class A energy waster?) or is it a design imperfection? Reread the thread. Understand. Now, RandomAudioGuy, next time don't do random stuff but mention brand/type as it is a bit wrong to want advice without giving enough information not to say it is irritating.
Jean-Paul, you've been very helpful and thank you very much.
I apologise for the frustrations caused to everyone. My initial questions were to confirm the voltage regulators and capacitors so they could be replaced. These questions have been answered and I'll be putting them in shortly.
While your suggestion of finding out the WHY is a great idea, I don't think I will be doing that. I had only intended to replace some of the components with new ones and people on here think I shouldn't even be doing that. So I think I'll put everything back and if it works, then great. If not, I'll wait till lockdown here is over and then find someone to have a look at it for me.
Again, thanks for yours and everyone else's help. I have no idea asking what types of voltage regulators and caps were would cause so much frustration for everyone.
  Reply to this post
Help with replacing capacitors and voltage regulatorsHide this!Advertise here!
Thread Tools
Supply capacitors for Voltage Regulators dbx01 Power Supplies 9 29th May 2015 12:21 AM
Series Pass Regulators driven by 3-terminal regulators SGK Power Supplies 8 13th March 2014 04:10 PM
Replacing Voltage Regulators mtl777 Parts 92 8th December 2007 11:55 PM
+/- with pos and neg regulators vs 2 pos regulators mr.duck Power Supplies 8 12th October 2006 04:27 AM
Need help replacing regulators Sampsa Solid State 0 24th June 2004 09:07 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
