First Volt? What is a 1 volt DC, 150 ampere supply used for?
Thread Tools
Old 23rd June 2021, 04:57 AM   #11
tomchr is offline tomchr  Canada
tomchr's Avatar
Would probably make a nice spot welder.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 23rd June 2021, 04:16 PM   #12
RJM1 is offline RJM1  United States
Find shorted tantalum capacitors?
Old 23rd June 2021, 07:28 PM   #13
PRR is offline PRR  United States
PRR's Avatar
I assume it is mostly selenium rectifiers, with a lump of iron in a corner.
Old 23rd June 2021, 08:06 PM   #14
egellings is offline egellings  United States
Maybe light spot welding.
Old 25th June 2021, 11:41 AM   #15
Mark Tillotson is offline Mark Tillotson
Originally Posted by Andersonix View Post
Hello DIY Brothers!
Recently I ran across a one volt, 150 A power supply.
What can you do with one big volt?
Cheers!
Drive a metal foil as a heater perhaps? Testing high current equipment? There'll be various labs round the world for which this is just the ticket for their next experimental set-up...
Some computer CPU's would run nicely from that come to think of it
Old 26th June 2021, 03:27 AM   #16
PRR's Avatar
Why still speculating? The logo says what it is.
Old 26th June 2021, 03:59 AM   #17
daqvin_carter is offline daqvin_carter  United States
Maybe make sure it does not have selenium rectifiers. Having one of those start gassing is sort of bad. I had an old Wurlitzer organ that started smelling bad and I knew it was a low voltage selenium rectifier. It was used to actuate the stops. Replaced that sucker quick.
Old 1st July 2021, 02:28 PM   #18
coresta is offline coresta  France
coresta's Avatar
for cathodic protection of undergrounded piping ... gaz, water, anything metallic will degrade as an electrolytic cathode in earth. When correctly polarized with an anodic sheet of metal , degradation will be lower
  Reply to this post
First Volt? What is a 1 volt DC, 150 ampere supply used for?Hide this!Advertise here!
Thread Tools
100 VOLT 20 AMPERE POWER SUPPLY yubilsal Power Supplies 4 2nd December 2014 04:34 PM
100 volt 10 ampere dv voltage regulator for split supply livenicely Power Supplies 0 19th November 2009 12:17 PM
speaker/amplifer volts, watts, ampere, impedance calculator palesha Solid State 11 16th August 2007 04:38 PM
Enough Voltage but not Ampère... MaXiZ Solid State 10 16th October 2003 01:17 AM
relation between ampere, voltage and distortion or linearity oliverniekamp Pass Labs 4 17th June 2002 08:38 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
