Toroid Transformer Winding
Thread Tools
Old 22nd June 2021, 04:27 PM   #1
JasonWatkins is offline JasonWatkins  United States
Default Toroid Transformer Winding
I've been goofing around with an amp design for a while now and am attempting to come up with a power supply that will use parts that I have on hand. I have several large toroidal isolation transformers that I have been wanting to use, but 120v isn't overtly useful here. I'm going to be using 6GC5's for the output, and they are happy at that voltage, but I want to use 6DJ8's in cascode on the front end, and I need at least 180v for those. A little more would probably be ideal. I was considering using a doubler to get that higher voltage, but I thought it might be neat to extend the secondary on one of those toroids to get whatever voltage I need. There is plenty of room for extra windings, and they ran at close to 10A steady-state in the equipment that I pulled them from. I thought maybe I could use the original "tap" on the secondary as the low voltage section and extend the winding to a new tap that would be the high voltage section. Then just have two bridge rectifiers, etc. I'd also have to add a filament winding. What I'd like to know is if that would introduce some sort of issue that I am not aware of. I could in theory wind a completely new winding for the high voltage, but that would be a lot more of a hassle. Possibly extend the original winding for the high voltage and then add a new winding for the low voltage. I'm not sure yet. If this goes well, I'd like to eventually use the rest of those toroids for other amp projects. Do any of you know of any problems I would encounter by doing this? If acceptable, I'm going to build enclosures for the toroids out of stainless steel sheet metal. I have a bunch of it on hand.
I've included a rough schematic to give a better idea of what I'm talking about. Voltages aren't exact here. It's just for illustration purposes.
Thank you for the help. I'd be lost without these forums.
Old 22nd June 2021, 06:24 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
To make a transformer work properly the amount of copper (weight) of the primary winding must equal the secondary windings.
So if say 1lb of copper is the weight of the primary and it makes up 220turns, the secondary may have 400turns but the actual weight of copper should be the same.
Just adding more turns is not the propper way to do it but adding an extra 10 - 15% wouldn't harm the efficiency much.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 22nd June 2021, 06:58 PM   #3
It's interesting that you mentioned that, because technically these aren't isolation transformers. They have a 1:1 winding on them, but they also had two high-current 45v windings that went to a very beefy inverter circuit and 5-6 smaller low voltage windings for the electronics. (I salvaged them from Hipot testers that were used in a manufacturing environment to test electric ranges) I removed all of the secondaries (aside from the 1:1) from the core of the transformer I've been messing with. I had originally considered using it as a benchtop isolation transformer for small projects.
Old 22nd June 2021, 07:22 PM   #4
egellings is offline egellings  United States
I'm not sure about the equal weight idea for the P and S windings in a toroidal xfmr.
Old 23rd June 2021, 02:00 AM   #5
PRR is offline PRR  United States
PRR's Avatar
Equal weight *tends* to be an economic optimum. It is widely violated at high and low voltages. (Very low voltage's fat wire won't bend well, and one gauge small may be far easier. Very high voltage won't use the 'ideal' gauge because it would be too fragile.)
At DIY profit margins and left-over parts, equal-weight may be moot. I'd certainly pull a 2Watt 6DJ8 off a kilowatt core.
> Attached Thumbnails Toroid Transformer Winding-dual-rectifier-jpg
I fear that in your plan, if you connect the two "grounds" together, smoke will escape.
Old 23rd June 2021, 02:17 AM   #6
rayma is offline rayma  United States
Yes, just so you don't miss that comment, your schematic won't work.
You will need two isolated secondaries.
Old 23rd June 2021, 02:29 AM   #7
So, perhaps a dedicated winding for each rectifier would be recommended? It worked in simulation but that doesn't mean too much.
Old 23rd June 2021, 02:32 AM   #8
Yes, two galvanically isolated windings, of the right voltages needed.
Old 23rd June 2021, 05:17 AM   #9
Okay then. That shouldn't be too much of a problem. I was just hoping I could save myself some work. The core is way overkill for what I'm working with, but it's what I've got. I hooked up a big 300 watt resistor to it and pulled 225 watts for a half-hour with no issues. It didn't even get warm. That resistor got hot enough to cook on though. I do have a smaller toroid that I may try to modify. It also has some lower voltage windings on it that I may be able to remove. All of these transformers are just taking up space in my shop as it is. I never really considered doing this before but it opens up some new exciting possibilities.
Old 23rd June 2021, 11:32 AM   #10
Ketje is offline Ketje  Belgium
Ketje's Avatar
No smoke, just the two outputs with the same high voltage and two diodes in the upper bridge doing nothing.
Mona
Toroid Transformer WindingHide this!Advertise here!
Thread Tools
Winding 1st toroid transformer timwaldvogel Construction Tips 14 4th March 2019 05:53 AM
Toroid transformer winding usa4356 Power Supplies 5 14th August 2015 01:38 AM
Tutorial: Compute the relative power of each winding in a multi-winding transformer Elvee Power Supplies 6 20th December 2013 04:43 PM
Building a high quality gainclone toroid coupling transformer with "tubeness" winding ionomolo Chip Amps 16 13th February 2008 01:20 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
