Tube use? 24->300V large cap charger with 300V 150mA reg
Thread Tools
Old 6th April 2021, 05:39 PM   #121
NickKUK is offline NickKUK
So.. Tracing back the noise - I can see that the Isense doesn't worry about the leading transient however the NPN does I believe. So I've added some snubbage
The output from the boost section is good and seems clean enough, the only variants in wave form is the variation from the PWM itself which is controlling the current but has an accumulative cycle and then decides it needs to have a fractionally larger gap - this occurs at 7KHz so it's easy to spot.
Now then..
Top is output into the load. Middle is output from the maida mosfet... and the bottom is the output from the SMPS.
So it appears that currently the mosfet is setup to allow uA through.. which isn't enough to correct.. so the 600mA is going through the D1 diode as it keeps it 20V separation.. so a little more current is needed through the regulator
Edit.. Turns out that that R1 is too large and that prevents the regulator from starting. The regulator is now starting up.. and the slow start should take about 900ms - the SMPS is already at 260V.. Let's see what happens after dinner
Old 6th April 2021, 07:08 PM   #122
Better..
Old 6th April 2021, 08:28 PM   #123
Simulation time 1.2 to 2.8 seconds gives:
Better FFT sim performance that could do with some additional tweaking.. if that means I can get 20uV ball park figure then I'll be extremely happy.
Old 7th April 2021, 08:09 AM   #124
So I've put the model onto the large amp model.. left it running overnight, now it's just reached 1.2 seconds so it'll need today to continue running and we should then have a few seconds of amp startup and operation to assess.
Old 7th April 2021, 11:16 AM   #125
Spicy appetiser from the large model.. this has a 10KHz 3.16V input signal and a 30Hz 3.16V input signal on the other channel. This is from the top of the output tubes on one channel.
It still needs to run for several more seconds to get a real output but this is looking promising.
Old 7th April 2021, 12:51 PM   #126
Update - same run... at 3.2 seconds or so.. still need a stretch of 3 seconds after it's warmed up to get a really decent FFT out of it.
Old 7th April 2021, 02:37 PM   #127
From the pre-out - 2 to 4 seconds. Looking very transparent as a power supply (yes I know the amp needs work).
Old 7th April 2021, 06:00 PM   #128
Ok last ones for today I suspect. 4.5 to 5.8 seconds:
At the headset load 32ohm. Left channel 10Khz 3.16V input, right channel is 30Hz 3.16V:
Left
Right
So apart from my amp's signal path not being anywhere near clean, the power supply (which I'm concerned with) looks very promising.
I still think the real value would be +20dB on that but until it's built you known nothing John Snow..
Old 7th April 2021, 08:28 PM   #129
Yee gawds.
Right channel is getting better by the second..
Old 8th April 2021, 07:14 AM   #130
Left and right - 5.0 to 12 something seconds of simulation time.
I think I could live with that. Some cross talk, I think it's onto tubing the amp a little better to lower the harmonic chorus that's currently in effect.
Tube use? 24->300V large cap charger with 300V 150mA regHide this!Advertise here!
Thread Tools
Noir, a two transistor headphone amp: class-A, single ended, 150mA bias Mark Johnson Headphone Systems 287 26th January 2021 12:18 PM
good driver tube with 150mA heater? SemperFi Tubes / Valves 21 14th May 2016 09:32 PM
WTB Lundahl LL1688-150ma brommermartin Swap Meet 0 4th March 2016 10:37 AM
Mosfet reg vs Mosfet shunt reg linuxfan Power Supplies 3 30th May 2013 01:30 AM
5kV DC / 150mA PSU for sale Bakmeel Swap Meet 0 1st November 2002 01:09 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
