Some advice would be apriciated.
I'm placing multiple modules, relay boards, relay volume controls and preamp pcbs in a chasis. They require multiple different voltages.
24VDC
12VAC
12VDC
Can I take a 12-0-12 transformer and tap off as shown in the attached? (Caps etc not shown)
I'm wondering if the common ground will cause an issue?
24VDC
12VAC
12VDC
No, it´s wrong.
On negative phase top winding gets shorted.
Besides, no end of 12VAC can be grounded.
To make all this clearer, DO draw filter capacitors and the 12VAC load.
Is it a tube filament?
Agreed, the 12VAC can't be grounded.
How does it get shorted?
Gary
So the idea, It's going to be a collection of modules running off a common supply.
1. Relay driven preamp input selector (No power on the signal path) 12VAC (rectifier on PCB)
2. Relay driven Stepped volume control (No power on the signal path) 12VDC
2. Single ended jfet RIAA pre 24VDC
3. Single ended jdet Buffer Preamp 12VAC (rectifier on PCB)
So I need 12VAC, 12VDC and 24VDC available
All PCBs will have a common ground through the signal path.
I've attached a more detailed drawing of my idea for the PSU.
I shouldn't be grounding any AC.
Thanks so far!
Thanks so far!
- Power Supplies
- Power Supply design for multiple modules
