Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#11 |
Double check you have the correct regulator in the correct side of the circuit.
Check the regulator pinouts: invariably different for pos & neg regulators! Check the datasheet for each type. |
#12 |
What is the current draw of the circuit you are powering?
What is the current rating of the transformer you are using? Transformer needs to be double what you think as you are supplying current to both pos & neg rails. |
#13 |
You can stack supplies just like you stack batteries. It's not sketchy. Same idea. Any supply will conform to whatever ground reference you assign to it. Just make sure that all your ground references are to the same potential (ie earth or safety ground).
#14 | |
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Support: DLCP NCXXXMP DLCP SMPS standby and eliminating power up / down pop | Fai | Class D | 0 | 23rd April 2020 10:11 AM |
Hypex DLCP/UcD400 build | ChrisHill | Class D | 49 | 27th May 2018 11:02 PM |
Hypex DLCP no analog audio output (help needed) | bourbon-neat | Digital Line Level | 2 | 18th February 2017 10:35 PM |
FS: Sitronik Amps, Hypex DLCP, Thel Power Supplys | Guitarfreak | Swap Meet | 5 | 12th February 2015 02:53 AM |
18V + 18V Power Adapter = +/- 18V Power Supply ? | staticGeneraor | Power Supplies | 2 | 13th April 2013 11:22 PM |
New To Site? | Need Help? |
