Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#11 |
What are R3-C6 and R4-C5 for?
What are CX1 and CS1 and RS1 for? Perhaps a schematic showing the Tx and secondary windings, and snubber parts, and the pcb and its parts would avoid confusion. |
#12 |
A quick sketch of the schematic
#13 |
The snubber is usually a C-RC, and is placed across each secondary half-winding, as it is the energy in each half-winding leakage inductance that needs to be constrained.
#14 |
My fault, the first resistor on the left should be a capacitor.
![]() In the pcb schematic it is a capacitor ![]() I can try to put a snubber circuit on each half winding. don't know it's gonna fit, but i can try. I read in different forums that it's no problem to put one snubber circuit over the outer taps, that's why i draw just one. ![]() |
#15 |
Check the power dissipated by the current limiting resistors for the LEDs. Don't want to let the smoke out.
#16 |
It will indeed make it a smokemachine
![]() The led is rated 20mA 3.2V. 4k7 with 50v will result in 10mA trough the led and near 0.5w in the resistor. I better pick a 0.5w or 1w resistor. Thnx ![]() |
#17 | |
Most new LEDs will happily operate at 2-5mA - perhaps worth checking LED intensity before settling on a resistor dropper value. Perhaps aim for resistor dissipation of no more than 40-50% of rating to avoid brown marks appearing on pcb over the years.
Unless you are very dedicated and have tools available, you won't know if your transformer has a significant level of leakage inductance, or if your power supply configuration is pushing a high level of peak rectifier current and turn-off dI/dt, or if your implementation is leaking rectification noise in to the audio path, and it would have to be a severe case for your ears to pick out any difference. |
#18 |
Thnx for the info,i will try different resistor value's for the led. Maybe 10k, if it's emits light is good enough
![]() The snubber circuit will be on each half winding, it fits on the pcb. I will try the quasimodo circuit on the transformer later ![]() Next week i'm gonna mill the pcb, all parts are arrived. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
grounding dual mono to mimick a mono block | mozarti | Chip Amps | 5 | 27th November 2014 10:07 AM |
Grounding for dual mono PSU and digital PSU | smithomo | Power Supplies | 4 | 23rd July 2013 09:53 AM |
making dual mono jack from single mono jack | dubmunkey | Analog Line Level | 2 | 12th October 2006 03:16 PM |
Single Mono's or Dual Mono? | Tazzy | Pass Labs | 8 | 3rd October 2002 03:03 PM |
Dual Mono - Anti Mono Power Supplies | pmkap | Everything Else | 3 | 16th February 2002 06:10 AM |
New To Site? | Need Help? |
