Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
Hello Everyone, i am starting a new project, i am going to make a PowerSupply for my X-Can V8 and my heed , i will use it as a learning experience, so i will try to make it as good as possible, fuigure i will try a lot of things to get it as good as i can.
![]() The easyest thing will be the PSU for my X-Can V8 sens it seams to only be a toroidal transformer around 30va and not much more, one that makes a third party PSU have added a EPCOS surge protection and a EVOX class X2 for filtering. is it a good idea to att surge protevtion and filtering ? if so what whold be a good rout to go ? something like a IEC with EMI filter or is it better to make a board for that ? The wall wart that come with 3 pins gives it 24VCT (12 0 -12) and 500mA dose anyone have a picture on how the X-Psu V8 looks like inside ? The next one is the powersupply for my Heed Audio Questar The Heed Q-Psu 3 that is the "real" one i shold get seams to use a 50VA transformer 8x diodes for bridge rectifier 2x10 000uf 63v 85c caps (on older modelse they have used Jamicon) 4x voltige regulators ( conectors have 4 pins 2x24v ) and a few smal caps and diodes. from what i can see they use one film cap before the rectifier from + to - what is the "best" way to do this, from what i have seen some use a cap and a resistor from + to - , then some use film caps like a 10nf in parallel with diodes in the rectifier. i am open for ideas ![]() is there any voltage regulators that you know of that will be realy good for this ? i know that there is a lot of questions (and there will be more) but i am just starting out in making my own circuits so bear with me ![]() i dont realy have a budget for all of this but sens this is for learning as well i might have a higher budget then i normaly whold, as long as it costs less then the originals ![]() ![]() have a nice day all ![]() |
#2 | |
Even using a wall transformer, you get less lightning pops and rf pickup if you put a RF filter in your preamp chassis. I salvage such from dead PC's (the PCAT power supply) or from dead flat screen televisions. The 11 turn toroidal choke of either product does a good job if installed near the input to the steel preamp case. Followed by the x cap across the line, (usually yellow .47 uf) and the surge filter (blue disk). As these last two devices fail short, a fuse before all this at the entrance to the case is required. OTOH if the transformer is in your preamp (not recommended), the IEC socket from a PCAT power supply has the Rf filtering built in. Also many other products you can salvage. Note using a wall transformer, the analog ground can be derived from a single voltage coming in with two voltage regulators or zener diodes with suitable RC filters following. As my mixer only had 6 op amps, I used cheap 1n5344 zeners. Note if you salvage a flat screen tv, the screen can be folded up and discarded in the trash. No recycling tag required if you do that, and saw up the case. Wear safety glasses & top grain leather or kevlar gloves. Happy recycling, or perhaps shopping.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey PV-1.3K, MMA-81502, Herald RA88a mixer, Steinway console, Wurlitzer 4500, 4300 |
#3 |
#4 | |
There is usually no need in film caps in the rectifier except in the RC-snubbers. If there is a possibility to use Shottky - then use them. Last edited by Vovk Z; 26th November 2020 at 01:35 AM. |
#5 | |
#6 | |
I live in an apartment so no hanging wires ![]() Well they arent expensive and i can order anything so if using Shottky whold be the best at this i will use some ![]() |
#7 |
It is free to use. Only your decision. I like to use varistors or suppressors if there is free space (somebody don't like to use them and think it is overkill). But there is strict rules for them, because they can be dangerous to use (risk of fire). So I can say that varistors or suppressors in mains circuits are not for young players.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
DIY Powersupply for UCD | nilsomat | Class D | 9 | 16th November 2006 10:12 AM |
Aleph powersupply design question | kasra | Pass Labs | 12 | 11th June 2002 06:47 AM |
basic question : reduce amps supplied by powersupply | fezz | Solid State | 0 | 26th March 2002 09:58 PM |
Aleph 2 LC powersupply ...question.. | hifi | Pass Labs | 16 | 3rd February 2002 06:27 PM |
Some Q about BSOZ Powersupply | hifi | Pass Labs | 20 | 31st December 2001 11:13 PM |
New To Site? | Need Help? |
