+/- 18V Low Noise Fast Transient Supply???
Thread Tools
Old 10th October 2020, 07:03 AM   #1
safesphere is offline safesphere  United States
Default +/- 18V Low Noise Fast Transient Supply???
Hello friends,
I need your expert help and guidance to point me in the right direction. I need a super low noise and fast transient response +/- 18V power supply for my phono preamp, but I am having a hard time finding any. I would be happy to buy it or build one from a kit (or at least a circuit board), but I don't have the expertise to design it myself (not from scratch anyway). Could someone please point me to a product or project or something to start from?
Input: 120V 60Hz
Output: +/- 18V (about 0.3A)
Speed and ultra-low output impedance over a broad bandwidth (ideally 3mOhm up to 100KHz)
I would appreciate any help. Thank you!
Old 10th October 2020, 07:15 AM   #2
jimk04 is offline jimk04  United Kingdom
Salas Ultra BIB for a state of the art approach.
Salas SSLV1.3 UltraBiB shunt regulator
Or if you want cheap and cheerful ready to go but with good performance...Studer 900 clone
low noise Pre-Amp / DAC power supply MJE15034 TL072 Regulator based on STUDER 900
Old 10th October 2020, 07:23 AM   #3
Indiglo is offline Indiglo  Australia
There's a choice of power supplies at sjostromaudio.com. You can buy from the webshop at sjostromaudio.net
Old 10th October 2020, 07:34 AM   #4
It looks fantastic, thank you! That thread is 237 pages... Do you know if the board is available for purchase? Thanks again!
Old 10th October 2020, 07:46 AM   #5
Look promising. Thanks for the link!
Old 10th October 2020, 07:53 AM   #6
If you contact member Tea Bag he is the one to ask. Be aware that there are some tricky ro source components but Teabag can supply you with those.
The Ubib is a shunt regulator. I dont know if you know what that means, I know I certainly didn't when I joined this forum! It means they require some planning and heat management is/ can be a factor to consider. Also by design they are not 'green' so depending on your personal circumstances that may also be a factor.
But having said that they are thought of very highly and are amongst one of the best psus I believe.
Edit...here is the group buy link
GB For Salas SSLV1.3 Ultra-BIB
I think if you contacted Teabag and asked nicely he will fix you up.
Old 10th October 2020, 08:01 AM   #7
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
The lowest output impedance and fastest regulator is in the diyaudio store:
Super Regulator – diyAudio Store
Widely tested and acclaimed:
https://linearaudio.net/sites/linear...%20JW%20F8.pdf
https://linearaudio.net/sites/linear...%20JW%20F5.pdf
Jan
Old 10th October 2020, 09:34 AM   #8
Super Regulator diyAudio Store
Jan
Superb. Thank you Jan! So, do I just put AD797 in place of AD825? What changes, if any, do I need to make for +/-18V instead of +/-15V? Also, the link says, "The regulator boards accept a DC input from your favorite transformer/rectifier/reservoir cap". Where can I get any help on this? Such as at least the schematics and BOM?
Thanks so much!
Old 10th October 2020, 11:03 AM   #9
jan.didden's Avatar
You should not use the 797 in this design; the 797, while superb in signal chains, has a tendency to instability in regulators.
Both Walt Jung and myself recommend the AD825 for maximum performance.
For the transformer/rectifier/reservoir capacitor, there are many designs here, and it is not critical at all. Even Google 'full wave rectifier' will show you lots of examples. To keep the two regs fully independent, with no shared grounds, it is best to use a transformer with two separate secondary windings. For +/-18VDC, secondaries of 18VAC on a 100VA transformer is fine.
Use fast, soft recovery rectifier diodes, and don't overdo the capacitor value; it has no performance advantage and might generate fast current transients that propagate into the circuit. Something like 4700uF/35V would be fine.
Jan
Old 10th October 2020, 11:42 AM   #10
If I may ask....would that be 4700uf per rail or overall?
+/- 18V Low Noise Fast Transient Supply???Hide this!Advertise here!
Thread Tools
ultra low noise power supply and low noise amplifier ambrosia168 Power Supplies 8 13th October 2017 03:43 PM
Single supply vs. dual supply and noise, I can't find a proper solution Plecto Power Supplies 16 2nd August 2013 06:14 PM
Nice power supply with fast recovery diodes peranders Solid State 3 24th August 2004 04:04 PM
Super fast, low noise phono preamp dioklecijan Analogue Source 30 19th July 2004 10:52 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
