+/- 18V Low Noise Fast Transient Supply???
Thread Tools
Old 12th October 2020, 01:09 AM   #31
gigigirl is offline gigigirl
Hi safesphere, Interesting range of P/Supplies to choose from. What phono amp & cartridge will you be using for your trial.
Cheers
Old 12th October 2020, 08:03 AM   #32
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by safesphere View Post
With so much great advice here, I plan to start with building 2 or 3 different designs to see if any of them sounds better.
That is the real diy spirit! Good for you!
Jan
Old 12th October 2020, 08:16 AM   #33
TNT is online now TNT  Sweden
Originally Posted by dreamth View Post
that is exactly what you DON'T need with a phono preamp.
Well, to make the scratches etc as "silent" as possible, it needs to handle them swiftly and without distorsion...
More distortion to the people! Timing . . . . is paramount.
Old 12th October 2020, 09:36 AM   #34
safesphere is offline safesphere  United States
Cheers
My phono prreamp is the original first Rega Aria MM/MC
I should be getting soon one of the good models of Lyra
Old 17th October 2020, 12:22 AM   #35
Giordano is offline Giordano  Hungary
Hello,
I've just finished design and now order pcba for a balanced TPA headphone amp. Do you know if for the Salas SSLV1.3 UltraBiB shunt regulator, the gerber files are available? Or, for other superreg designs? I need positive and negative supply both.
Thanks,
JG
Old 18th October 2020, 08:28 AM   #36
O.K., so, I understand the gerber is not public. I have a question. If I just make a board design based on the superreg design here, am I breaking any written on non written rule?
Thanks,
JG
Old 4th December 2020, 05:34 AM   #37
Originally Posted by jan.didden View Post
The lowest output impedance and fastest regulator is in the diyaudio store:
Jan
Hello Jan,
I have bought the boards for your regulator and I have a quick question. There are ten 120uF caps on the BOM. Can I replace them with either 100uF or 220uF without negatively affecting performance? If I can, which of them (C1-C10) should be 100uF and which 220uF? And which must stay 120uF? Thank you so much!
Alex
  Reply to this post
+/- 18V Low Noise Fast Transient Supply???Hide this!Advertise here!
Thread Tools
ultra low noise power supply and low noise amplifier ambrosia168 Power Supplies 8 13th October 2017 03:43 PM
Single supply vs. dual supply and noise, I can't find a proper solution Plecto Power Supplies 16 2nd August 2013 06:14 PM
Nice power supply with fast recovery diodes peranders Solid State 3 24th August 2004 04:04 PM
Super fast, low noise phono preamp dioklecijan Analogue Source 30 19th July 2004 10:52 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
